electrical problem when Hot - Honda Motorcycles - FireBlades.org
 8Likes
  • 3 Post By unslow1
  • 1 Post By BigdaddyPaz
  • 2 Post By unslow1
  • 1 Post By MrPickwick
  • 1 Post By H8ta_Hurta954
post #1 of 15 Old 09-26-2017, 8:51 AM Thread Starter
Quoted: 3 Post(s)
I have a 1997 CBR 900RR that I bought a battery a month ago because I thought it was a battery problem, now it has happened 2 times again. Riding on the highway and stopping and starting right away is no problem. but when I ride very slow in stop and go bumper to bumper traffic for over 30 minutes, the bike feels very very hot, the aluminum frame is so hot I can
t touch it. But the Temp gauge never gets into the red, the fan will come on and it stays at about 3/4 on the temp gauge no higher. The problem is if I accidently kill the bike in traffic, then it will not crank back up, It feels like the battery is dead. if I pull over to the side and sit there for a hour then it will crank back up, even though the battery feels weak. the multimeter I put on the battery shows 13.1 volts at 4,000 rpms, idling it is right at 12.0, does this sound like rectifier has overheated? its the original rectifier I believe.
jward is offline
post #2 of 15 Old 09-26-2017, 11:39 AM
Quoted: 487 Post(s)
Re: electrical problem when Hot
Hi , does sound like your Reg/Rec , the only way it can get rid of excess is to dump it as heat, is your battery getting hot also?
MrPickwick is offline
post #3 of 15 Old 09-26-2017, 12:49 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
If you're "testing" your battery while your machine is running, you're really only testing the output of your stator and R/R. The battery needs to be separate from the bike (or disconnected) to accurately test voltage and/or amperage.
...and IF the R/R is original, 21 years ain't a bad run
unslow1 is offline
post #4 of 15 Old 09-27-2017, 8:34 AM Thread Starter
Quoted: 3 Post(s)
I tore in thebike today and found the connector going to the rectifier is all burnt and melted and wires are touching each other, the wires for about 5 inches from rectifier are all burnt and hard. I got a mess, it appears the previous owner put the wrong rectifier on the bike. the five wire connector has 3 wires up top and two spaced in bottom, the rectifier I took off the bike has 3 wire connectors on the bottom and 2 on the top . I don't understand that one.
jward is offline
post #5 of 15 Old 09-27-2017, 9:07 AM
Quoted: 487 Post(s)
I'd certainly invest in another Reg/Rec , but tidy up the wires and connecters first
post #6 of 15 Old 09-27-2017, 10:14 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Purchase a new stator (and gasket) and OEM quality battery (Yuasa) as well, unless the one you just bought is.
In my opinion, it's better to replace the whole system for "piece of mind".
unslow1 is offline
post #7 of 15 Old 09-27-2017, 6:59 PM
Quoted: 749 Post(s)
Reputation Power: 102
Good advice right there. I think most of us have "been there, done that".
I did both of my 900's with aftermarket MOSFET regulators that are a lot bigger, but just going with an OEM one should net you another 18-20 years of riding.
IMG_4445.JPG‎   IMG_6634.JPG‎   IMG_6635.JPG‎
IanDoohan is offline
post #8 of 15 Old 09-28-2017, 11:58 AM Thread Starter
Quoted: 3 Post(s)
does anybody have a picture of how the wires go in the connector as my connector is completely melted and the wires were all out of order, i have 3 yellow 1 green and 1 red and white striped one.
starting on left top it looks like green then yellow then red/white
on bottom it looks like yellow and yellow
HELP
jward is offline
post #9 of 15 Old 09-28-2017, 12:17 PM
Quoted: 487 Post(s)
HELP
Here you are ,from your manual
reg.PNG‎
post #10 of 15 Old 09-28-2017, 1:23 PM
Quoted: 749 Post(s)
OEM should only have 5 wires to the Reg/re
IMG_3989.JPG‎
post #11 of 15 Old 09-28-2017, 3:54 PM
Quoted: 103 Post(s)
Reputation Power: 9
I just learned a hard lesson, DO NOT BUY CHEAP ELECTRICAL PARTS FROM EBAY, spend the money and buy reputable parts, I bought a Stator and Reg/rec form Ricks motorsports, quality stuff.
unslow1 likes this.
BigdaddyPaz is offline
post #12 of 15 Old 09-28-2017, 6:03 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
I too, recommend Rick's equipment
IanDoohan and BigdaddyPaz like this.
unslow1 is offline
post #13 of 15 Old 09-29-2017, 3:20 AM Thread Starter
Quoted: 3 Post(s)
Hello Guys, thank you for all the help and knowledge as I am lost with electricity. I replaced the r/r and got the wires all figured out and plugged in. now the bike is charging 13.2 volts at idle. BUT when I increase the rpm's to 2,000 rpm's the volts go down to 12.0 and stay there up to 5,000 rpms. So I think you have told me I should be looking at a new stator now. I did do a check on the 3 yellow wires and they averaged about 46 to 47 volts crossing them all three ways at 5,000 rpms.
jward is offline
post #14 of 15 Old 09-29-2017, 4:18 AM
Quoted: 487 Post(s)
Yup , new stator
BigdaddyPaz likes this.
post #15 of 15 Old 09-29-2017, 5:51 AM
Quoted: 7 Post(s)
I totally agree the statement about cheap parts... i usually go to bikebandit to get my parts... but I gotta check out this Ricks equipment.
Georgia 954 RR.......
H8ta_Hurta954 is offline
954 hot start problem roblambert General Discussion 5 02-07-2016 9:45 PM
'05 cbr1000rr HOT START problem rdacrew12 General Discussion 6 09-01-2014 11:48 PM
f2 electrical problem psychward26 Honda CBR 600 0 07-06-2013 5:15 PM
Hot start problem Intimidator Honda FireBlade 7 04-14-2005 8:09 AM
Electrical Problem Mattxp800 Honda FireBlade 14 08-24-2003 5:33 PM
