cuts out at around 8k - Honda Motorcycles - FireBlades.org
 5Likes
post #1 of 30 Old 03-13-2018, 7:21 PM Thread Starter
Quoted: 3 Post(s)
I have a 2010 cbr1000rr that cuts out and backfires around 8k, it's all stock except the exhaust, It didn't start tell I removed the baffle so I put the baffle back in and the issue proceeded, I have been all over looking for ideas, I have cleaned the tank the injectors all work, and the mesh screen in the tank and it hasn't worked I'm at a loss.
JONZZZY is offline
post #2 of 30 Old 03-14-2018, 2:21 AM
Quoted: 487 Post(s)
Re: cuts out at around 8k
Not worked on the later Blades, but this sounds like a mapping issue, does your bike have a Power Commander, with a new exhaust it should need re-mapping , a Dyno run should find the fault, and have you tried putting the stock can back on
BigdaddyPaz likes this.
MrPickwick is offline
post #3 of 30 Old 03-14-2018, 7:45 AM Thread Starter
Quoted: 3 Post(s)
no power commander, and I no longer have the stock can
JONZZZY is offline
post #4 of 30 Old 03-14-2018, 7:46 AM Thread Starter
Quoted: 3 Post(s)
as for the dyno I made the apt today so if he finds it I'll post for the next guy that had this issue
unslow1 and MrPickwick like this.
JONZZZY is offline
post #5 of 30 Old 03-14-2018, 8:14 AM
Quoted: 487 Post(s)
Nice one @JONZZZY
post #6 of 30 Old 03-14-2018, 2:10 PM Thread Starter
Quoted: 3 Post(s)
dyno showed nothing other than running rich, fixed that but still cuts out at the exact same spot
JONZZZY is offline
post #7 of 30 Old 03-14-2018, 2:55 PM
Quoted: 487 Post(s)
Maybe a few other things to check, fuel line, IAT sensor, MAP sensor , and looking at other symptoms , it came up with faulty side stand switch, could be one to check by just bypassing it for one run only, dont know where you are , but bariometric pressure could be a factor, could be ECU restricting fuel
post #8 of 30 Old 03-14-2018, 7:09 PM
Quoted: 712 Post(s)
Reputation Power: 102
Fouled plug for some unforeseen reason? Typically though, it will run like crap throughout the entire rev range (that the fouled plug will allow it to). Running rich for a basically stock bike seems kind of odd to me. Generally bikes are as lean as they can be, up to a point to meet emissions standards. Rich with no mods is a kind of a paradox. It should be as lean as lean can get. Maybe the richness fouled a plug(s).
Does it get through the 8k interruption, then on to red line ok? And how was the rich condition fixed without a PC?
What is the history of the bike as far as you know?
IanDoohan is offline
post #9 of 30 Old 03-15-2018, 12:47 PM Thread Starter
Quoted: 3 Post(s)
doing the plugs today then going to test it again and see what happens hopefully it's that easy.
JONZZZY is offline
post #10 of 30 Old 03-15-2018, 6:27 PM Thread Starter
Quoted: 3 Post(s)
plugs replaced no change still cuts out, I'm at a total loss, checked sensors all are good I'm at a complete loss, but after plugs it had one good run that crapped out again, bypassed the kick stand sensor no change, will continue checking sensors I guess
JONZZZY is offline
post #11 of 30 Old 03-15-2018, 9:04 PM
Quoted: 712 Post(s)
FPR maybe?
post #12 of 30 Old 03-15-2018, 10:04 PM Thread Starter
Quoted: 3 Post(s)
going to try the cps, read another thread and sounds like that could be my issue, the only thing is it's not throwing any codes for anything, the checks engine light isn't even coming on. so now it just kinda plug and play.
JONZZZY is offline
post #13 of 30 Old 03-18-2018, 8:44 AM
Quoted: 17 Post(s)
Reputation Power: 8
Sounds like you've had it apart at least a couple of times by now so the only bit of advice that I'll offer is to check, re-check & then triple check ALL of the connections that were touched (unplugged & plugged back in) during the teardown/re-assembly process.
Disregard if this has already been done...
Are you also using the correct sparkplugs called for in the service manual ?
-'02 Silver/Black CBR 954RR
-'06 Black/Metallic Gray RC-51
-'11 Graphite Black CBR 1000RR
(sold)
-'08 Pearl Orange CBR 600RR (sold)
COBRA90GT is offline
post #14 of 30 Old 03-24-2018, 7:53 PM Thread Starter
Quoted: 3 Post(s)
new update bike now the tach will go crazy check engine light came one then never cut out again while the check light was on. any new ideas?
also had a new battery put in and new injectors, also cleaned and rechecked all the connections
JONZZZY is offline
post #15 of 30 Old 03-25-2018, 4:26 AM
Quoted: 487 Post(s)
Can you run a check on stored faults, there should be something there
Cuts out Gazzer Honda CBR 600 8 05-25-2012 5:41 AM
cuts out ozflash Honda FireBlade 16 12-08-2011 1:05 PM
cuts out dcb Honda FireBlade 2 07-17-2011 4:09 AM
01 RC Cuts out ??? Brett Haven Honda RC51 6 01-14-2009 5:22 PM
Cuts showmethebombs Off-Topic 5 01-23-2005 10:18 PM
