Stiff Gear Changes - Honda Motorcycles - FireBlades.org
 2Likes
  • 1 Post By Turbz34
  • 1 Post By MrPickwick
post #1 of 6 Old 04-18-2018, 4:51 AM Thread Starter
Stiff Gear Changes
Hi guys, Iíve got a 2005 Fireblade track bike that Iím having issues on the gear shifts.
When selecting gear, it slams into gear and feels like the clutch isnít fully engaged, as it tries to roll forward. Itís also near impossible to reselect neutral unless I turn the bike off. So Iím guessing thatís because itís under load. It has also grabbed false neutral a few times the last time (and first time) I had it out on the track.
I just changed the clutch lever on it and ran it through the gears while on the stand, and the shifts felt smooth, but back on the ground itís needing the brake to stop it from taking off more now than before.
Sheís got a STS Slipper Clutch if that matters.
Now I guess my question is, do you guys think it sounds like my clutch isnít engaging fully to allow smooth shifts, and if so, how can I adjust that? Or, could something else be causing my issue?
Sorry for my ignorance. Just getting into road racing and havenít done much maintenance on bikes as yet.
Cheers for any help you guys can offer.
Turbz
Turbz34 is offline
post #2 of 6 Old 04-18-2018, 5:25 AM
Quoted: 487 Post(s)
Re: Stiff Gear Changes
Hi, did it do this before you changed the clutch lever, and have you tried bleeding the clutch
MrPickwick is offline
post #3 of 6 Old 04-18-2018, 5:32 AM Thread Starter
Yeah it did it before. And no, Iíve not bled the clutch. Like I said, Iíve not done any real motorcycle maintenance before.
Turbz34 is offline
post #4 of 6 Old 04-18-2018, 5:42 AM
Quoted: 487 Post(s)
Okey dokey, when the bike is off the ground, engine running and in neutral, does the rear wheel turn ( it should turn slowly and be able to stop easily by placing your hand on the tyre) or does it race
post #5 of 6 Old 04-18-2018, 7:03 AM Thread Starter
In neutral it doesnít turn. In gear with clutch engaged it races, probably more so with the new clutch lever. But the guy I bought it off said itís normal when the slipper clutch is cold. But itís not something Iím familiar with.
So Iím still assuming the clutch levers, especially the new one, arenít engaging fully by the time itís pulled in against the bar.
MrPickwick likes this.
Turbz34 is offline
post #6 of 6 Old 04-18-2018, 7:26 AM
Quoted: 487 Post(s)
Yes , there can be a problem with new clutch/brake levers especially if Chinese, but if it was happening before the change, maybe bleeding the clutch line could help, have you got the workshop manual?
IanDoohan likes this.
Shifting down stiff/hard BladeRiderLuke Honda FireBlade 4 04-23-2017 6:39 AM
Stiff clutch on NC23 smithyithy Honda CBR400RR 4 04-30-2013 7:16 PM
Really stiff clutch question Godsmacked New Rider Orientation 19 11-06-2011 8:41 AM
stiff clutch lever? rewerbcrx Honda FireBlade 7 05-17-2009 12:07 PM
Stiff Throttle ashtanga Honda FireBlade 4 12-17-2006 11:17 AM
