1000rr owners!! Replacing my 954 Calipers / Lower Forks - Honda Motorcycles - FireBlades.org
 12Likes
post #1 of 21 Old 05-05-2018, 2:03 PM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Hi all,
I have a 954 race bike (see below pics) and i'm needing to upgrade my calipers to gain better brake performance. And before you say it yes I have tried almost every pad, brake lines master cyclinders etc.
My initial thoughts are that I will change out the lower part of the fork from a 1000rr that runs Radial Calipers, whether it be a 04 to 17 model?
Please could I ask some 1000RR owners if they could measure the top of lower fork to the wheel centre for me. (See pic below of my bike as an example) Also the diameter of the stanction would be appreciated.
Thanks in advance,
Mike
Lower Fork Measurement.jpg‎
mikecarr4 is offline
post #2 of 21 Old 05-05-2018, 2:18 PM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Re: 1000rr owners!! Replacing my 954 Calipers / Lower Forks
Pics
1.jpg‎
post #3 of 21 Old 05-05-2018, 2:20 PM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Pics 2
2.jpg‎   3.jpg‎
post #4 of 21 Old 05-06-2018, 4:03 AM
Quoted: 733 Post(s)
Reputation Power: 102
I can’t help you with your question, but have one of my own.
What does it feel like to do the Cadwell Leap?? Just looks so freakin awesome.
IanDoohan is online now
post #5 of 21 Old 05-06-2018, 4:11 AM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Ha no problem.... Its a pretty special corner! Try and treat the entry like a normal right hander but dont drive too hard up it, lean forward, hold on tight, close your eyes and hope for the best!!
IanDoohan likes this.
post #6 of 21 Old 05-06-2018, 4:15 AM
Quoted: 733 Post(s)
Man, that must be some rush!
post #7 of 21 Old 05-10-2018, 6:40 AM
Hi all,
Thanks in advance,
Mike
2012 blade = 1125mm, hope that helps.
Kevo954 is offline
post #8 of 21 Old 05-10-2018, 6:43 AM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Thank you.
I found out the following for info.
954 is 117mm
2004: 117mm
2011: 117mm
2018: 90mm (Note: This is an SP2 with Ohlins suspension so might well be different measurement to standard)
post #9 of 21 Old 05-10-2018, 11:34 AM
Quoted: 51 Post(s)
I'd be really interested to know if you manage to do this, it was something I considered when I fitted 929 forks to my SC33. I managed to pick up a pair of new (old stock) fork lowers very cheap so tried to unscrew the ends from my old lowers but without success. The are very tight and thread locked IIRC.
BenelliBlade is offline
post #10 of 21 Old 05-10-2018, 12:09 PM
Quoted: 253 Post(s)
Why not just get a set of 1000rr forks? It would seem that if the tops won’t fit in the triple trees you could replace the fork lowers. The needle valves and perhaps even fork rods should be able to swap over also.
Another thing is, how much braking performance improvement do you need? Do you have a quantifiable measurement?
-My 06 Fireblade Build Thread
-Her 02 CBR600F4i Custom Suspension
-My 07 CRF230F sold
-My 97 XR100
-07 CRF50F son's
-92 CB750 She lets me ride it, Jetted
-13 CRF110F, 01XR50 Daughter's
Jaybird180 is offline
post #11 of 21 Old 05-10-2018, 12:48 PM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Yes they are supposed to be very tight but a bit of heat on them should do the trick! Hopefully!!
post #12 of 21 Old 05-10-2018, 12:55 PM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
I thought about the 1000rr option but with them being a shorter fork than the 954 this will lower the front end too much for me. Also, I have MUPO K911 fork cartridges on my race bike so these would no longer be any use and I would have to buy a 1000rr set..£££££
Breaking performance wise, I can't quantify this entirely in terms of stopping power but what I can say is I have raced a Ducati 1299 Panigale and I could break later on that than my 954 so in terms of slowing me down.... better brakes has to be worth at least another second a lap for me...
Jaybird180 likes this.
post #13 of 21 Old 06-03-2018, 8:24 AM
Quoted: 2 Post(s)
Reputation Power: 6
it's possible to swap the lower part from the cbr 1000rr forks (04/07) on the 954 ones,on the italian forum (Fireblade.it) many members did that,you have also to put spacers between the bolts of the calipers because the 954 has bigger brake discs compared to the 1000rr ones.
if i remember correctly i have printed that topic,if i will find,i will give you better details
IMG_2348.jpg‎
[IMG][/IMG]
mauro954 is offline
post #14 of 21 Old 06-03-2018, 8:32 AM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
Hi yes I have just changed over the lowers on my forks. I actually used the lower with the stanction fitted and swapped over my MUPO cartridges, All works perfect! Brembos on order!
2018-05-29 17.02.43.jpg‎   2018-05-29 17.02.36.jpg‎
post #15 of 21 Old 06-03-2018, 8:33 AM Thread Starter
Quoted: 11 Post(s)
Reputation Power: 8
I was also amazed that the 954 mudguard fits the 1000rr!! Perfecto!
