954 Tachometer reading - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 05-11-2018, 7:56 PM Thread Starter
Quoted: 2 Post(s)
Reputation Power: 15
Hi all.
So i recently built a 954rr that i got last winter for $600 for the track. I rebuilt the motor to OEM spec and i must say, it runs amazing, i cleaned up everything, new crank rods, pistons, everything! Having a fresh motor is nice i must say.
Now that everything is back together i am stumped on this one where the tach is not working anymore. I am trying to figure out where the tach signal comes from. I know the yellow and green wire feeds the tach from the ECU so the ECU sends the signal to the tach. But what sends engine speed to the ECU that i can double check. I checked signal all the way back through the wire and im getting 0V but everything else works fiine.
Keep in mind this is my 2nd 954 so ive been swapping parts to make sure everything is working good. Tach works ECU works but I am not getting any thing to the ECU. Any help will be greatly appreciated
nyknick1015 is offline
post #2 of 10 Old 05-12-2018, 3:40 AM
Quoted: 487 Post(s)
Re: 954 Tachometer reading
Hi have you tried the test on page 19-12 of the manual?
MrPickwick is offline
post #3 of 10 Old 05-12-2018, 10:52 AM Thread Starter
Quoted: 2 Post(s)
that is the first thing that i tried. I am getting 0V on two separate ECM's from both my bikes
post #4 of 10 Old 05-12-2018, 10:53 AM Thread Starter
Quoted: 2 Post(s)
Yep that is the first thing that I tried. I get 0V on two separate ECM's from both my bikes so i think I am not getting something IN on the ECM
post #5 of 10 Old 05-12-2018, 12:09 PM
Quoted: 487 Post(s)
Have you got another set of clocks you can swap over
post #6 of 10 Old 05-12-2018, 12:28 PM Thread Starter
Quoted: 2 Post(s)
yep bought a brand new one 0 miles from honda. Everything works except the tach. I don't have a FI light trouble code which is weird if something was unplugged
post #7 of 10 Old 05-12-2018, 1:45 PM
Quoted: 487 Post(s)
Maybe take a look at the black harness connector into the ECU could be a loose pin coming from spark wires to ECU , not reading the pulse
post #8 of 10 Old 05-12-2018, 6:15 PM
Quoted: 159 Post(s)
Reputation Power: 122
Haven't looked in the manual so just spitballing, but the signal comes from the trigger coils in the ignition right? Since you had the engine out I would verify that it is hooked up correctly.
fj1200rj is offline
post #9 of 10 Old 05-27-2018, 5:55 PM Thread Starter
Quoted: 2 Post(s)
I'm going through everything and I still can't figure it out I'm going to go through every connector once over because I really wanna get it on the track
post #10 of 10 Old 05-27-2018, 8:36 PM
Quoted: 711 Post(s)
Reputation Power: 102
The signal should go from the ignition rotor pick up (aka pulse generator) on the right side of the crank to the cam pulse generator, then to the ECU, then from the ECU through the harness to the tach on the yellow green. If all of those components are good, and there are no splits/burns/shorts, its probably an ECU issue.
I'm speaking in general terms here, so if someone has more specific knowledge, I won't be offended.
IanDoohan is offline
1000rr owners!! Replacing my 954 Calipers / Lower Forks mikecarr4 Honda FireBlade 20 06-04-2018 6:03 AM
2002 954 w/Ohlins For Sale! $4700 OBO in Wisconsin davef Motorcycles For Sale 2 05-18-2018 10:15 AM
2003 954 power issues Kylep7888 General Discussion 4 05-12-2018 5:59 PM
