93 CBR900RR Looking for Original 3 Wire Ignition - Honda Motorcycles - FireBlades.org
 4Likes
  • 1 Post By IanDoohan
  • 1 Post By shrekusa
  • 1 Post By BenelliBlade
post #1 of 13 Old 05-12-2018, 8:38 AM Thread Starter
Awaiting E-Mail Confirmation
Quoted: 27 Post(s)
Hey all
just started a restoration project, looking for an original 3 wire ignition/key for a 93 CBR900RR. The bike I brought had a busted one and I have the 3 wires coming from the Harness as per below.
Shrek
IMG_6251.JPG‎
shrekusa is offline
post #2 of 13 Old 05-12-2018, 6:55 PM
Quoted: 733 Post(s)
Reputation Power: 102
Re: 93 CBR900RR Looking for Original 3 Wire Ignition
Originally Posted by shrekusa View Post
Hey all
Shrek
Ebay for an aftermarket one, or maybe a used one, and a used harness to get the proper harness side connector??
Trying to get a used OEM one might be difficult.
shrekusa likes this.
IanDoohan is online now
post #3 of 13 Old 05-13-2018, 7:15 AM Thread Starter
Quoted: 27 Post(s)
Thanks for the quick reply, looks like I have found one on Ebay - message the seller to take a photo of the wiring ends so I can see three wires.
IanDoohan likes this.
shrekusa is offline
post #4 of 13 Old 06-04-2018, 7:29 AM Thread Starter
Quoted: 27 Post(s)
Folks
I was able to buy a brand new ignition for my 1993 CBR900RR, below picture is the male end of the wiring (3 wire) which connects to the wiring harness. I am however not familiar with this type of connector.
Questions
1.Is there a female side of the connector normally on the wiring harness or
2.just slot in the standard flat connectors to each/correct slot?
Shrek
Plug from new Ignition - trying to find female connector to add to wiring harness.jpeg‎
shrekusa is offline
post #5 of 13 Old 06-04-2018, 7:37 AM
Quoted: 733 Post(s)
Harness should def have a male matching connector.
Shown with the red wires, upper right.
post #6 of 13 Old 06-04-2018, 7:43 AM Thread Starter
Quoted: 27 Post(s)
Thanks Ian
do you know the name of these connectors? Trying to see if I can buy it as a single item as hate to buy a complete wiring harness.
Cheers
Shrek
shrekusa is offline
post #7 of 13 Old 06-04-2018, 8:03 AM
Quoted: 733 Post(s)
Thanks Ian
Cheers
Shrek
I don’t believe they have a name specifically, but Ebay searching may come up with something similar. I googled “4 pin connector” while doing my resto/mod on my 93 with the gauges because I had to swap the male ends for female ends. Worth a shot, and they should have pictures.
post #8 of 13 Old 06-04-2018, 8:56 AM Thread Starter
Quoted: 27 Post(s)
Bloody Ripper Ian
Just found it https://www.ebay.com/itm/Ricks-Motor...MAAOSwPYpa8HBe
Cheers!!!!
shrekusa is offline
post #9 of 13 Old 06-04-2018, 9:22 AM
Quoted: 733 Post(s)
Bloody Ripper Ian
Cheers!!!!
Don’t get the anointing oil out just yet, that add says it’s for the reg/rec, be sure it’s the same spacing as your rec/rec connector and ignition connector before you buy!
post #10 of 13 Old 06-04-2018, 9:42 AM
Quoted: 51 Post(s)
I think this is the connector you need. The Reg/Rec connector is 5 way, not 6 way.
BenelliBlade is offline
post #11 of 13 Old 06-07-2018, 11:27 AM Thread Starter
Quoted: 27 Post(s)
thanks team - only 3 connections are actually used so should it matter either way?
shrekusa is offline
post #12 of 13 Old 06-07-2018, 2:41 PM
Quoted: 733 Post(s)
It shouldn’t, the other slots can surely be empty. But, if you only got one side (as the reg/rec connector is only one 1/2 of the connector) it may not line up to what you already have on the ignition.
I think Benelli’s option is better.
post #13 of 13 Old 06-07-2018, 5:20 PM
Quoted: 51 Post(s)
If you Google for "6.3mm 6 way" they are quite widely available, you should be able to get one within the US very easily.
