954 to 980 project - Honda Motorcycles - FireBlades.org
 1Likes
post #1 of 22 Old 06-03-2018, 10:20 PM Thread Starter
954 to 980 project
So I've had my 2002 CBR954RR for about a year now and I start hearing some rattling coming from the front of the tank. It only happens under load and when accelerating rather hard. With 73,000 miles I figured I might need to adjust the valves. So I checked my clearance.
All in spec. (Exhaust was 0.25 to 0.27 and Intake was 0.13 to 0.15). Cam Chain Tensioner was good too (manual).
I poked around the motor and the web and I find out that it's just a noise they make. Bullsh!t.
Someone mentioned piston slap, and I thought, "oh no. Please, not that."
Yes that. Cylinder 4 was the worst with scoring that you can feel. Yes, my carpenter, callused fingers were able to feel that.
So now I am undergoing the 980 conversion. Gonna replace the 75mm pistons with 76mm. I just need to find a machinist...
20180531_193744_1528078746897.jpg‎   20180531_193752_1528078780894.jpg‎
Sarcs.954RR is offline
post #2 of 22 Old 06-03-2018, 10:21 PM Thread Starter
Here is number 1
20180603_114116_1528078878557.jpg‎
post #3 of 22 Old 06-03-2018, 10:22 PM Thread Starter
Numbers 2 &3
20180603_113937_1528078926596.jpg‎
post #4 of 22 Old 06-03-2018, 10:23 PM Thread Starter
And number 4...
20180603_114109_1528078970631.jpg‎
post #5 of 22 Old 06-04-2018, 11:10 AM
Quoted: 102 Post(s)
Reputation Power: 8
Re: 954 to 980 project
that sucks!
BigdaddyPaz is offline
post #6 of 22 Old 06-05-2018, 10:38 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 383 Post(s)
Reputation Power: 58
subscribed
unslow1 is offline
post #7 of 22 Old 06-05-2018, 12:58 PM
Quoted: 46 Post(s)
I'd have expected the engine to be burning quite a bit of oil with that amount of wear.
BenelliBlade is offline
post #8 of 22 Old 06-17-2018, 11:43 AM Thread Starter
It burned a bit if I hit it hard
post #9 of 22 Old 06-17-2018, 11:47 AM Thread Starter
Update: Tear down in progress...
Need a 24mm allen to get the swing arm off. Then I can split the case
20180617_084351_1529250417931.jpg‎   20180617_084528_1529250426185.jpg‎
post #10 of 22 Old 06-18-2018, 8:43 AM
Quoted: 46 Post(s)
Do the 954 cylinders need to Nikasil plated after reboring?
post #11 of 22 Old 06-23-2018, 6:50 PM Thread Starter
I believe they do. Not sure yet where I'm gonna get it done though, if it does in fact need it.
post #12 of 22 Old 06-23-2018, 6:58 PM Thread Starter
More progress...
Got the swing arm and bracket off. Removed oil pan and started with the bolts.
Found a little surprise. Oil pan had A LOT of copper? bits inside. I hear that's it's normal when there's piston slap so I'll clean it up and hopefully I can determine what part(s) it came from so I can replace it(them).
20180623_155305_1529794571548.jpg‎   20180623_155316_1529794728629.jpg‎
IanDoohan likes this.
post #13 of 22 Old 06-25-2018, 8:06 PM
i have the same issue with my 954... 36k miles kept fouling plug number 1, tore it down and scarred cylinders on all 4. A guy who does head work at a reputable machine shop in town indicated Cylinder Services | Millennium Technologies was the place to send the block to.
good luck on your rebuild!
cbrnole is offline
post #14 of 22 Old 06-26-2018, 7:20 PM
Quoted: 2 Post(s)
You're gonna have to send your upper case to Millenium. They'll bore and replate the cylinders. They can also send you the pistons too. I had them do the cylinders for my 04 CBR1000. I got a decent deal on my +2mm pistons from them.
k2piks is offline
post #15 of 22 Old 06-26-2018, 10:53 PM Thread Starter
I found a local guy that a buddy of mine used to use, Screwie Lewie's Motorsports. Not sure if he does the plating himself but at least it will get done. Not sure yet what it will cost, but one thing at a time. I'll get them bored at the machinist around the corner, CBS Specialists. They said it would be about $67 a hole. I just need to get one of the pistons first so they have exact measurements.
02 954 Low Speed Driveability Issues JMooreHarrier2 Honda FireBlade 27 06-26-2018 11:06 PM
1000rr owners!! Replacing my 954 Calipers / Lower Forks mikecarr4 Honda FireBlade 20 06-04-2018 5:03 AM
Mototeck undertail 954 Gat0rbait Honda FireBlade 0 05-30-2018 9:23 PM
2002 954 w/Ohlins For Sale! $4700 OBO in Wisconsin davef Motorcycles For Sale 2 05-18-2018 9:15 AM
2003 954 power issues Kylep7888 General Discussion 4 05-12-2018 4:59 PM
