Fork seal leaking - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 03-27-2019, 11:00 PM Thread Starter
Quoted: 10 Post(s)
Fork seal leaking
Just had brand new fork seals installed.leaking alot .took the bike back to the shop.thinking the mechanic put seals in upside down?
Jimmyzx636 is offline
post #2 of 7 Old 03-29-2019, 1:09 AM
Quoted: 625 Post(s)
Reputation Power: 101
Re: Fork seal leaking
It’s possible. We’ve seen stranger things that shops do.
IanDoohan is offline
post #3 of 7 Old 04-01-2019, 11:54 PM
Quoted: 6 Post(s)
The mechanic would have to be drunk or stoned to put seals in the wrong way and they would act like a cup resulting in some serious by pass!
tubehead is offline
post #4 of 7 Old 04-04-2019, 1:07 AM
Quoted: 4 Post(s)
There was probably some damage to your fork tube that your mechanic didn't notice and its killed the new seal straight away. If that's the case they should replace it for free, even backyard mechanics check the fork tubes before putting them back together. Hope it gets sorted.
Splint is offline
post #5 of 7 Old 04-07-2019, 10:39 PM
Quoted: 102 Post(s)
Reputation Power: 8
The mechanic could have damaged the seal when he put ti on, but he would have had to really damaged it bad for it to leak like that. like someone said, the tube could have been damaged and the mechanic did not notice it.
BigdaddyPaz is offline
post #6 of 7 Old 04-08-2019, 8:49 AM
oldbastard's Avatar
Quoted: 55 Post(s)
Reputation Power: 15
I'm pretty sure that what happened to you is exactly what the other guys say, that the seal was not put in correctly. Especially if it is leaking more after the repair than before.
What I want ed to add to the thread was to say that I had a problem with a fork where a rock had dinged the chromed surface, and it started leaking. I didn't spot the ding at first, and just replaced the seal, which of course started leaking very soon afterwards. then I got up close with it, and saw the ding, which was about 1.5mm long and 0.5mm wide, and the chrome had cracked and formed a sharp edge which was slashing the seals. So I got out the dremel with the diamond disc and did my best to dress away the ding, as you can see it's through to the brass and not completely smooth, but it does the job. The new seal I put in after the smoothing job has been in there for a year without any leaks. Not a kosher job but cheaper than a new fork leg.
IMG_20180527_190001.jpg‎
oldbastard is offline
post #7 of 7 Old 04-11-2019, 10:04 AM
Quoted: 7 Post(s)
Best do it yourself mate. I did. There are some excellent videos out there on Youtube.
I used a bit of plastic piping to get the seals home (its all in the videos :-))
Any damage to the forks and the seals will be knacked. If its leaking alot, either upside down fitting (!) or they've knacked the forks.
It was a 929, then a DL650 - but when the 954 came up ..
Youngman is offline
Front fork replacement davejh77 General Discussion 6 03-21-2019 6:53 PM
CBR 929 Tire Removal Video Torque655 Honda FireBlade 2 12-15-2018 8:43 PM
front fork swaps?? geno13r Streetfighter 2 11-30-2018 12:08 PM
Wanted: Fork tube for a 93 900RR chuckhunter General Discussion 14 09-07-2018 2:53 PM
Front fork leak - OEM or AFM kahlilj Honda FireBlade 20 08-26-2018 4:35 AM
