Is this slight movement normal? - Honda Motorcycles - FireBlades.org
 3Likes
  • 1 Post By MrPickwick
  • 2 Post By IanDoohan
post #1 of 9 Old 03-31-2019, 9:33 AM Thread Starter
Quoted: 4 Post(s)
I am currently replacing right clip on and I noticed there is a slight movement on the steering head lock nut I can twist it about 0.5 cm is this normal I take it shouldn't be because it's a locknut! Or maybe I'm wrong Any ideas Photos showing amount of movement enclosed
IMG_0846.JPG‎   IMG_0847.JPG‎
vesco929 is offline
post #2 of 9 Old 03-31-2019, 10:18 AM Thread Starter
Quoted: 4 Post(s)
Re: Is this slight movement normal?
Just an update I decided to fiddle with the Bearing to see if it was tightly on and I could move it by hand and I was shocked that I could twist the whole Bearing assembly by hand the bottom bearing and the locknut Now I hate dealing with Bearing adjustment (never know if I've done it right) but even I know this isn't right I think I have to get the Haynes out and do a full bearing adjustment.
Every cloud maybe I was 'lucky' to have a small off last August cause wouldn't know about these loose bearings otherwise- I'm pretty sure bearings this loose are dangerous Could the bearings have come loose because of my crash the front of bike took a good whack but I could still ride it home Don't think my crash created these loose bearings? But would be interested to hear views thanks
vesco929 is offline
post #3 of 9 Old 03-31-2019, 10:45 AM
Quoted: 487 Post(s)
Hi can't see your locking washer there ,#8
locking washer.JPG‎
BigdaddyPaz likes this.
MrPickwick is offline
post #4 of 9 Old 03-31-2019, 5:16 PM
Quoted: 625 Post(s)
Reputation Power: 101
There is some play that is normal between the cap nut and the lock nut, only because sometimes the lock washer doesn’t line up perfectly to articulate with them. I’ve had some I had to loosen just a hair to get the tabs on the lock washer to line up. No worries.
Bill it’s there, if you zoom in on the slot near the tank mount bolts you can see one of the tabs bent up in there.
Gunk and MrPickwick like this.
IanDoohan is offline
post #5 of 9 Old 04-09-2019, 9:15 AM Thread Starter
Quoted: 4 Post(s)
Sorry for late reply yes understand I think all is fine in Haynes it says lock nut can be moved by hand Thanks for your replays appreciated
vesco929 is offline
post #6 of 9 Old 04-09-2019, 9:17 AM Thread Starter
Quoted: 4 Post(s)
But thinking how's it a 'locknut' if I can remove it with my fingers? I don't understand
vesco929 is offline
post #7 of 9 Old 04-10-2019, 9:13 AM
oldbastard's Avatar
Quoted: 55 Post(s)
Reputation Power: 15
Yes that's strange because in the photo the tab of the lock washer is bent up into the recess in the castellated nut. So it shouldn't move because there is also a tab on the inside of the lock washer that engages in a groove in the shaft. Could be that someone forced the locknut open without folding out the external tab, and because the inner tab is smaller, it got sheared off...so the lock nut can now move....
oldbastard is offline
post #8 of 9 Old 04-10-2019, 11:30 PM
Quoted: 102 Post(s)
Reputation Power: 8
in the picture it looks like hes missing nuts? did you remove to show what is going on?
BigdaddyPaz is offline
post #9 of 9 Old 05-08-2019, 6:44 AM
Quoted: 18 Post(s)
Make sure you take the nuts completely off and inspect the threads and bearings for damage. My buddy wrecked my 929 before I purchased it off him and I ended up riding for a long time with broken bearings and a stripped stem and it was a tank slapping machine. It also sheared the bottom of my gpr steering stabilizer
msf0002 is offline
Mark's on inside of flywheel normal? jayadams66 Honda FireBlade 2 09-17-2018 10:24 PM
954 main drive (little) sprocket rattles - normal? NicksCBR Honda FireBlade 2 06-15-2018 11:14 AM
