Dodgy turn signal switch - Honda Motorcycles - FireBlades.org
 4Likes
  • 1 Post By kame
  • 1 Post By IanDoohan
  • 1 Post By 954duder
  • 1 Post By machinehead
Old 04-13-2019, 3:12 PM Thread Starter
Quoted: 4 Post(s)
Hi there
Part way through a 400 mile(!) day trip this week on my 954, the turn signals started behaving strangely and then stopped working completely. The indicators still flash when I activate my alarm and, after a bit of fiddling about with the handlebar switch, I got the right turn signal to work properly. So it looks like a loose connection in or around the switch.
I have a very poor digital copy of the manual but the little diagram in Section 19, showing continuity across the various wires in the connector, is illegible. So could some kind person please post a picture of that small continuity test diagram for the turn signals?
Thank you
954duder is offline
Old 04-18-2019, 12:49 PM Thread Starter
Quoted: 4 Post(s)
.....is anybody out there who can help please...?
954duder is offline
Old 04-18-2019, 1:38 PM
Re: Dodgy turn signal switch
I just had maybe the same issue on my 954 and fixed it following this guide:
Basically, the grease in the turn signal switch assembly had gotten stiff and gluey, and it needed to be cleaned and regreased.
Gunk likes this.
kame is offline
Old 04-18-2019, 2:07 PM Thread Starter
Quoted: 4 Post(s)
Excellent. That's really helpful, I'll give it a go. Many thanks.
954duder is offline
Old 04-22-2019, 1:09 PM Thread Starter
Quoted: 4 Post(s)
Ok that's a very useful video thanks, but the 954 turn signal/light assembly only seems to have 1 retaining screw, and removing this does not enable the assembly to be opened up.
Am I missing something? Or do I just need to be a bit more er, forceful...?
Thanks
954duder is offline
Old 04-23-2019, 4:31 PM
Quoted: 625 Post(s)
Reputation Power: 101
Thanks
There should be 2, one on the front side and one on the rear side (to equally clamp it to the bar). Should be (2) 5mmX20mm pan screws.
unslow1 likes this.
IanDoohan is offline
Old 05-04-2019, 5:45 AM
Quoted: 2 Post(s)
I had the same issues, but couldn't fix it no matter what I tried, so I just bought a complete new OEM switch assembly.
Problem fixed. Not all that expensive.
Jacker is offline
Old 05-04-2019, 3:45 PM Thread Starter
Quoted: 4 Post(s)
Thanks both. I seem to have solved it (for now at least) with copious amounts of GT85 spray and lots of wiggling around (the switch, not me) 😁
Gunk likes this.
954duder is offline
Old 05-04-2019, 8:47 PM
Quoted: 2 Post(s)
I would give it a spray with contact cleaner or take it apart and clean the moving parts first.
Bullit01 is offline
Old 05-06-2019, 6:57 AM
Quoted: 27 Post(s)
once the dirt gets in there then the contacts can 'burn' as they don't make proper connection. WD40/contact cleaner will help but strip and clean the contact is better. I had this same problem with my 929, stripped, cleaned and is perfect again - cost £0
unslow1 likes this.
machinehead is offline
cbr929 lower temperature fan switch jayadams66 Honda FireBlade 12 04-14-2019 10:38 AM
954RR OEM Turn Signal Plugs UnfortunateFish Honda FireBlade 5 12-28-2018 3:40 AM
Front turn signals 3 wire to 2 wire? Duality Honda FireBlade 6 08-06-2018 2:36 AM
Starter switch issue? cbrosu Honda FireBlade 1 06-19-2018 8:59 PM
