Cracked fork cbr 929 fire blade - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By IanDoohan
post #1 of 4 Old 05-19-2019, 3:21 PM Thread Starter
The bottom of my right fork is cracked just by the pinch bolts under the axle nut. What the chances of the being welded.
20190519_144843_1558293614209.jpg‎   20190519_144853_1558293641995.jpg‎   20190519_144909_1558293664874.jpg‎   20190519_144902_1558293683273.jpg‎
Mking is offline
post #2 of 4 Old 05-19-2019, 3:53 PM
Gunk's Avatar
Quoted: 448 Post(s)
Reputation Power: 22
Re: Cracked fork cbr 929 fire blade
I would say that’s knackered, you’d be much better to try and source a good second set of forks rather than try to repair it.
Looks as if the pinch bolts have been massively overtightened, they don’t need much, about 16 ft lbs, that’s all.
1993 CBR900 RR P
2013 Triumph 675 Street Triple
1994 CBR900 RR R Urban Tiger Project (now sold)
Gunk is offline
post #3 of 4 Old 05-20-2019, 5:46 PM
Quoted: 611 Post(s)
Reputation Power: 100
My non welding knowledge opinion is that anything can be repaired. Aluminum is tricky though, but I would say it can be fixed. You could probably source a lower tube for cheap somewhere and rebuild it. It looks like there was a bolt straight through there? And the helicoil looks like its buggered up. You may have to load it all up with fill, drill, and retap the rearward portion.
I guess it depends on cost, available resources, and time.
Gunk likes this.
IanDoohan is offline
post #4 of 4 Old 05-21-2019, 5:36 AM
Quoted: 27 Post(s)
id go for a good 2nd hand set. there was a recall for cracking on teh forks iirc, unless that was just the 954 version, however the checking wasn't like yours though which looks like brute force!
machinehead is offline
CBR 929 Mirrors hornetjo Honda FireBlade 4 04-20-2019 2:29 PM
2001 CBR 929 with flatspot around 3000 rpm Crazytaxi Honda FireBlade 0 04-02-2019 5:12 AM
Fixing a CBR 929 ECU srobinson Honda FireBlade 3 02-09-2019 12:38 PM
2000 929 caught on fire HoondaRider Honda FireBlade 2 09-15-2018 4:48 AM
