Cbr 954 not starting - Honda Motorcycles - FireBlades.org
 2Likes
  • 2 Post By jdoni
post #1 of 7 Old 05-28-2019, 7:40 AM Thread Starter
Was out on the bike and it just stopped tride to start it but nothing unplugged my pc3 but nothing checked all the connections the bike does everything right ie fuel pump primes but wont start so any ideas would be appreciated
Cbr 954 2002
crupi23 is offline
post #2 of 7 Old 05-28-2019, 8:51 AM
Quoted: 487 Post(s)
Re: Cbr 954 not starting
Hi matey , first of all would check the battery for voltage, then check for loose connectors , then see if you have a spark, have you got any fault codes
MrPickwick is offline
post #3 of 7 Old 05-29-2019, 9:27 PM
Had a similar problem the other day with my 2018 CBR1000rr. The battery (six years old) was no longer strong enough to start the bike. My guess is that the starter got jammed in the wrong position or something. It would not even start with jumper cables... A couple of guys tried to start the bike by pushing it and engaging the clutch, but no luck. However, that effort was enough to disengage the stuck starter. Hooked the battery up to a nearby vehicle with jumper cables and the bike started right up. Got me home safe and sound. Purchased a new battery for $90 or so the next day. All is fine now.
PeterM is offline
post #4 of 7 Old 05-29-2019, 10:01 PM
Quoted: 29 Post(s)
Why a six year old battery in a one year old bike?
unslow1 and IanDoohan like this.
jdoni is offline
post #5 of 7 Old 05-29-2019, 10:05 PM
Good catch! It’s a 2008!
PeterM is offline
post #6 of 7 Old 05-31-2019, 12:52 PM
Quoted: 747 Post(s)
Reputation Power: 102
Oh SH!T! jdoni is BACK!
IanDoohan is offline
post #7 of 7 Old 06-01-2019, 7:25 AM
Quoted: 41 Post(s)
Cbr 954 2002
Have you read the ECU for any fault codes? There is a jumper in the loom under the seat you need to short - workshop manual explains how to do it, what the codes are, and how to reset any fault codes. A search on hear will tell you how or PM me.
There is a multi plug by the RH side of the airbox that feeds power to the coils - split this and check all the connections are nice and clean. Check the cam sensor wire (LH engine, wire runs across the top to the engine) and make sure it's not got a broken/cut wire.
You said the pump primes ok - when you crank the engine can you hear the pump running at the same time? It should and if it does then the ECU is getting a pulse from the crank sensor which is good news for you!
hth
machinehead is online now
