2001 CBR929RR Chassis Swap - Honda Motorcycles - FireBlades.org
 6Likes
  • 2 Post By machinehead
  • 1 Post By MACE_
  • 2 Post By fc3s driver
  • 1 Post By msf0002
post #1 of 7 Old 06-03-2019, 5:08 PM Thread Starter
Hi there.
So I'm looking for any one who has done a chassis swap that can offer any advice before I take on this monumental task at the weekend. I've a 2001 CBR929RR
My chassis is cracked on the inner side and I have a replacement good to go. But, are there any tips for the poor buggers who may have done this before and learnt a few do's and don'ts along the way. The bike is fully assembled so I'm starting at the beginning.
Any advice appreciated.
Cheers
Sgreen503 is offline
post #2 of 7 Old 06-03-2019, 5:19 PM
Gunk's Avatar
Quoted: 466 Post(s)
Reputation Power: 22
Re: 2001 CBR929RR Chassis Swap
Best advice is to have another complete bike parked next to it for reference, usually not possible.
1993 CBR900 RR P
1994 CBR900 RR R Urban Tiger Project (now sold)
Gunk is offline
post #3 of 7 Old 06-03-2019, 5:23 PM
Quoted: 27 Post(s)
Originally Posted by Sgreen503 View Post
Hi there.
Cheers
Take photos, lots of them, before during and after. Wiring connectors should be simple. Keep nuts bolts etc with the respective part. Use labels as necessary, freezer bags are good to keep bits together too. Good luck 😊
MACE_ and nigelrb like this.
machinehead is offline
post #4 of 7 Old 06-03-2019, 6:54 PM
Quoted: 39 Post(s)
Reputation Power: 6
post pics.
i knew these dudes back in the day who would swap frames for you overnight....the next day they would give you your bike .....
and a handful of bolts
Ziplock bags and a sharpie will go along way in this venture
IanDoohan likes this.
MACE_ is offline
post #5 of 7 Old 06-04-2019, 12:42 AM
Quoted: 7 Post(s)
Did this on 954 over the winter. Actually pretty easy. Seeing how frame mounts to the motor and is separate from the swing arm makes this super simple. Hardest I had was getting the wiring shoved back in to place. Connectors are all self explanatory, there are no duplicates so you cant really mess that up.
Here is a picture of how I supported the bike...
20181120_191237.jpg‎
IanDoohan and Gunk like this.
fc3s driver is offline
post #6 of 7 Old 06-05-2019, 12:30 AM
Quoted: 18 Post(s)
Reputation Power: 10
It’s super easy to swap frames. It’s only 4 bolts to the motor and 4 bolts to the subframe. Just got my frame back from powder coat this weekend... the hardest part is dealing with the steering stem and getting it tightened correctly. Make sure to inspect your steering head bearings and races and replace them if they are worn. I swapped to a 954 swingarm as well 😬
F429CC95-E466-4CC4-9058-3A77A298E1BB_1559708830450.jpeg‎   0DE9FAAC-B304-435B-9D50-C486077D0C55_1559708945487.jpeg‎
msf0002 is offline
post #7 of 7 Old 06-05-2019, 12:37 AM
Quoted: 18 Post(s)
I guess I over simplified it a bit since you can see the other bolt locations in the rear of the frame (it’s been a month since I took it apart) there are a couple bolts in the rear of the frame too. But I swear it’s not hard. I will be putting it all back together this weekend hopefully if not the weekend after so if you need pictures while it’s still apart while I’m reassembling I will happily post them for you.
Gunk likes this.
msf0002 is offline
