Head Removal in frame - Honda Motorcycles - FireBlades.org
 5Likes
  • 2 Post By msf0002
  • 1 Post By Gunk
  • 2 Post By nigelrb
post #1 of 5 Old 06-08-2019, 4:47 PM Thread Starter
I have a 2001 929 can I remove the head with the engine in the frame?
Onemoreride is offline
post #2 of 5 Old 06-13-2019, 9:52 PM
Quoted: 21 Post(s)
Reputation Power: 11
I’m not 100% but my bike is apart right now for the second time and I’m gonna say no. But even if you could/can it would not even be close to worth it. It’s so easy to take the frame off the motor it would be 10 times harder to try to do with it still attached to the frame
IanDoohan and nigelrb like this.
msf0002 is offline
post #3 of 5 Old 06-14-2019, 2:54 PM
Gunk's Avatar
Quoted: 518 Post(s)
Reputation Power: 24
Re: Head Removal in frame
Originally Posted by msf0002 View Post
Iím not 100% but my bike is apart right now for the second time and Iím gonna say no. But even if you could/can it would not even be close to worth it. Itís so easy to take the frame off the motor it would be 10 times harder to try to do with it still attached to the frame
I agree, it just seems a bit of bodge to do it in situ, it would be much better to remove and do the work properly on a bench.
nigelrb likes this.
Gunk is offline
post #4 of 5 Old 06-14-2019, 3:09 PM
nigelrb's Avatar
Quoted: 259 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
And, if you're so inclined, you can then do a meticulous clean of both engine and frame!
IanDoohan and BigdaddyPaz like this.
2001 CBR9290RR; 2003 CBR954RR; 2018 CBR1000RR SP2; 2020 CBR1000RR-R SP on order;
2002 VTR1000 SP-2; 1985 VF1000R; 1985 NS400R; 2018 C125 Super Cub;
2007 MV F4 1000R;
2020 Triumph Daytona Moto 2 Limited Edition
nigelrb is offline
post #5 of 5 Old 06-16-2019, 10:36 AM Thread Starter
Thanks for the replyís. The head will come out with the engine in the frame. The came chain guides have to be taken loose and removed. That clears the head to be carefully removed through the front (of course all the cooling has been removed). Remove the foam that is stuck to the frame on each side of the head. The bolts that are on the outside of the cam chain tunnel require a little thought to remove especially the rear one. Bottom line is take your time and go slow. Upon reinstalling the head go in reverse. All bolts can be reached for proper torquing down.
