I give up NEED HELP crank no spark . - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 06-18-2019, 6:08 PM Thread Starter
Quoted: 2 Post(s)
I own 02 954 ,bike ran excellent one touch it start . long story short sat for a year .I try to start it not happening so after I read all the Threads about no start I bought new battery ,new clutch dioud, new starter relay with 30A fus , after all that tested the ignition pulse generator I was getting .2 V , ok so got a used one I got .4V . still crank no start , just to clarify with the gas tank on I can hear my fuel pump running , so my stop & run swiech good < N green light comes on. so any have any Idea where to go from there ? is the used ignition pulse generator bad , or I'm missing something pls need help thank you
Nouf919 is offline
post #2 of 10 Old 06-18-2019, 9:02 PM
Quoted: 4 Post(s)
Re: I give up NEED HELP crank no spark .
Mine had the same problem after it sat for a while. I just added fuel additives ethanol and Isopropyl alcohol if I'm not mistaken. Started right up afterwords.
Dealia is offline
post #3 of 10 Old 06-18-2019, 9:27 PM Thread Starter
Quoted: 2 Post(s)
I wish it was a fuel issue ,it's no spark issue . When I stored the bike I took the gas tank out & when I put it back together I put in new fuel pump filter so fuel delivery is perfect , can't get it to spork . thank for though .
Nouf919 is offline
post #4 of 10 Old 06-18-2019, 11:33 PM
Quoted: 21 Post(s)
Reputation Power: 11
Did you empty the old gas and put new in before you tried to start it? Even if you only cranked it a few times on old gas you probably toasted the plugs. It happened to me before. You can get plugs online now for a reasonable price. They were expensive the last time it happened to me&#x1f62d;
msf0002 is offline
post #5 of 10 Old 06-19-2019, 1:08 AM Thread Starter
Quoted: 2 Post(s)
I put in a new fuel pump so gas was frish . it is an electrical issue definitely not fuel issue ,I'm not getting any spork , I put in new spark plugs .thank you for trying
Nouf919 is offline
post #6 of 10 Old 06-19-2019, 3:37 PM
Location: was on the left coast, now in central Va(dont ask)
Quoted: 10 Post(s)
Reputation Power: 6
no spark on any cylinder?
did you do all the replacement of diodes ect before issue showed up?
feelfree is offline
post #7 of 10 Old 06-19-2019, 4:34 PM Thread Starter
Quoted: 2 Post(s)
no spork on all 4 , update after testing this morning I found out I have a short in the electric sys .I was getting 11V from the ground side , after plugging & unplugging , I found the short or let just say I track it to the sub hournest that connect to the speedo , but it not the speedo shorting out it something going to the speedo , so magically lol if I pull the clock/fan fuse that will eliminate the short .I thought bing If I eliminate the short I'll get spark wrong still no spark , tested the fan motor & it good no short . where to go from there ?
Nouf919 is offline
post #8 of 10 Old 06-19-2019, 4:51 PM Thread Starter
Quoted: 2 Post(s)
I had the Issue with the clutch dioud it had a melt down so that was taking care of properly , starter solenoid it brand new .
Nouf919 is offline
post #9 of 10 Old 06-24-2019, 9:57 AM
Quoted: 45 Post(s)
have posted in your other threads
machinehead is offline
post #10 of 10 Old 06-24-2019, 12:21 PM Thread Starter
Quoted: 2 Post(s)
Yes I did but no replay .....update I rebuild & fix my wiring harness, I had melted some wiries , so I replace all bad wirries the proper way , I reconnect every thing now my fan comes on constantly, so I thought oh shi- I massed up so I took off the bike inspected again , found out that my ECM on the grey side is shorting out my electrical sys . long story short , I need ECM .
Nouf919 is offline
