CBR 900RR SC28 Wheels - Honda Motorcycles - FireBlades.org
 4Likes
  • 2 Post By IanDoohan
  • 1 Post By Gunk
  • 1 Post By Supermotodaz
post #1 of 13 Old 06-25-2019, 1:16 PM Thread Starter
Quoted: 4 Post(s)
Just brought a 1992 German import sc28 blade, I didn't check my error when I brought the bike but found it has a 17" upgrade front wheel and a rear wheel that matches the front.( both 3 spoke design I,m assuming from the CBR 600 F3 ).
I want to make the bike original and I can find plenty of the earlier wheels available but it seems there were at least three fitments on the SC28 models, does anyone know if there's a specific part number code that's stamped on the wheels to indicate a 2002-2003 fitment so I can source the correct ones.
Supermotodaz is offline
post #2 of 13 Old 06-25-2019, 2:49 PM
Quoted: 759 Post(s)
Reputation Power: 102
Re: CBR 900RR SC28 Wheels
The rear wheel of the 900 was a 6 spoke 17 x 5.5, so if yours matches the 17" front as a 3-Spoke, the front is not an F3. More likely a VTR1000F US "Superhawk".
You're post is a wee bit confusing though, for us here in the states, anything that is 2002-2003 is a 954, not an SC28. The SC28 ran from 92-95, then in 96 they changed to the SC33 (RRT). There is nothing definitive to indicate the year on a wheel, but the SC28 with the 16" 6 spoke shouldn't be hard to find. The SC28 will have different FRONT variations based only on a few factors.
1) color (all years)
2) speedo gear drive on left hub (93-94 US) (92-93 UK)
3) change to electric speedo on the 95 US model (94 UK model with foxeye headlights and sprocket fed speed sensor).
I hope that kind of helps out.
Post some pics please
Gunk and nigelrb like this.
IanDoohan is offline
post #3 of 13 Old 06-25-2019, 4:36 PM
Gunk's Avatar
Quoted: 523 Post(s)
Reputation Power: 24
Easiest solution is to stick a matching original set on, despite all the hype, they ride perfectly OK with 16” front wheel. I’ve had both and I can’t tell a lot of difference.
Duncan893 likes this.
Gunk is offline
post #4 of 13 Old 06-25-2019, 11:58 PM Thread Starter
Quoted: 4 Post(s)
Sorry just realised I mistyped in 2002-2003 , I meant 1992-1993.
Thanks for the excellent info, are there any differences on the rear wheel on the SC28 models or are these all the same.
IanDoohan likes this.
post #5 of 13 Old 06-26-2019, 12:00 AM Thread Starter
Quoted: 4 Post(s)
Yes this is my plan now I know the fitment I require.
post #6 of 13 Old 06-27-2019, 10:37 AM
Quoted: 759 Post(s)
There are slight differences in the SC33 rear wheels. for the SC28, 92-95 should all work with no problems. The SC33 changed a bit with the space between the swingarm, so the spacers spacers are a different length on the sprocket side, and the sprocket carrier spacer is different.
post #7 of 13 Old 06-27-2019, 5:28 PM Thread Starter
Quoted: 4 Post(s)
Found a set of wheels which are meant to be early fireblade . In the centre of the spoke on the front wheel is a stamp number 93. Any chance that this relates to the year.
post #8 of 13 Old 06-28-2019, 8:48 AM Thread Starter
Quoted: 4 Post(s)
post #9 of 13 Old 06-28-2019, 8:49 AM Thread Starter
Quoted: 4 Post(s)
https://i.postimg.cc/vmCPSxWT/cbr2.jpg
post #10 of 13 Old 06-28-2019, 8:50 AM Thread Starter
Quoted: 4 Post(s)
https://i.postimg.cc/L58ZtNn1/cbr1.jpg
post #11 of 13 Old 06-28-2019, 8:51 AM Thread Starter
Quoted: 4 Post(s)
Would you say these are 1992-93 fitment wheels.
post #12 of 13 Old 06-28-2019, 10:52 AM
Quoted: 759 Post(s)
Judging by this picture I would say no, the left side hub (which I believe this is the left side from the direction of the spokes, and arrows on the rotor and wheel), does not have the provisions for the speedo drive gear. Thus not a 92-93 UK wheel.
post #13 of 13 Old 06-28-2019, 11:06 AM
Quoted: 759 Post(s)
My 94 VFR750F (same as the F3 and NC30 wheels) wheel that I used as my 17" replacement has this stamped on it.
So that led me to believe that the stampings mean nothing.
