97 900rr speedometer replacement - Honda Motorcycles - FireBlades.org
 4Likes
  • 2 Post By Gunk
  • 1 Post By Gunk
  • 1 Post By IanDoohan
post #1 of 5 Old 06-26-2019, 9:58 AM Thread Starter
Quoted: 55 Post(s)
Reputation Power: 2
All but one of the mounting tabs on my gauge cluster are broken off. It appears as though the last person tried to use some foamy type of adhesive to repair it. I'm not sure if roughing the surface and using a 2 part plastic resin will be strong enough to hold the tabs in place.
I've found one new lower case for it and i'd have to transfer all wires and internals over but i'd be keeping my gauges. I've also found one with busted gauges but everything else is fine. These two options are about $50 plus shipping.
Lastly, there's used units for $150+ shipping. I can see the wiring work just fine but I've never taken one of these clusters apart to see how difficult it is to transfer internals. I like the idea of the speedo having actual miles (although there's no telling how long it was -1/+2 so it's not actual anyways) but then again, my speedo needle bounces all over. I don't know if that's the fault of the gauge or the sensor. Would a new cluster fix the speedo issue? Is transferring the internals over worth my time? Would resin be strong enough to hold the unit in place (previous owner used a zip tie to keep it in place)?
Also, the 95 gauge cluster has the same mounting holes and connectors. The only difference is that the 95 has words for the light functions instead of symbols. Other than making the bike look more dated, probably nobody would notice it's not the proper year for the bike. Just an FYI for anyone wondering.
skant153 is offline
post #2 of 5 Old 06-26-2019, 4:16 PM
Gunk's Avatar
Quoted: 523 Post(s)
Reputation Power: 24
Re: 97 900rr speedometer replacement
I’ve swapped a rear case over on a ‘94 wasn’t difficult, just take plenty of photos
IanDoohan and nigelrb like this.
Gunk is offline
post #3 of 5 Old 06-26-2019, 4:41 PM Thread Starter
Quoted: 55 Post(s)
Reputation Power: 2
what haven't you done Gunk? I'll have to remember photos. i'm horrible about documenting my work.
skant153 is offline
post #4 of 5 Old 06-26-2019, 4:49 PM
Gunk's Avatar
Quoted: 523 Post(s)
I drew a wiring diagram as well which really helped.
It did seem like it was going to be a really daunting task and I couldn’t find any YouTube videos on how to do it, so I just ploughed in and had a go and it all worked.
nigelrb likes this.
Gunk is offline
post #5 of 5 Old 06-27-2019, 10:53 AM
Quoted: 759 Post(s)
Reputation Power: 102
Skant, you'll notice that even though Gunks bike is a 94 (UK model), it has the 95 (US) gauges. It still has the idiot lights, but they are in a straight across row rather than in the little cube BUT, it has an electronic speedo, no cable. So it may not work on the 93-94 bikes. UNless you want to buy all the parts to convert it to an electronic signal which I did on my 93, from eBay of course, then put in an F4i digital dash with a clock as well
Gunk likes this.
IanDoohan is offline
