SwingArm chain+sprockets replacement problem? - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By unslow1
post #1 of 4 Old 06-27-2019, 1:07 PM Thread Starter
Quoted: 4 Post(s)
Had a small off last August and dented swingarm so got round to changing it. I'm a diy mechanic so this was biggest job I've done, I'm diy but I'm terrible for detail and doing things right so can't figure this out? Decided to change sprockets and chain at the same time.
Bad start couldn't remove 24mm hex so went round corner to friend in garage and he did a bit of welding etc and loosened the nut. Swingarm off new (secondhand) in new sprocket on plus front sprocket here's photo.
When putting new front sprocket on couldn't tighten it even with foot hard on rear brake, it just spun in both directions. Put in gear and then was able to tighten to 54nm but not sure if I've broken something?
New rear sprocket and chain rear wheel on all tightened started engine put in first gear and chain acts like it's not seated correctly sounds very bad not smooth as before. Anyone tell me what I've done wrong?
Have to say my swing arm bolt is still loose haven't gone round to friend at garage yet to tighten swingarm bolt to 118nm would this be why my chain isn't running true? Any info appreciated Thanks
IMG_0153.JPG‎
vesco929 is offline
post #2 of 4 Old 06-27-2019, 1:19 PM
nigelrb's Avatar
Quoted: 267 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
Re: SwingArm chain+sprockets replacement problem?
Sounds to me as if you've put a rear wheel spacer in the wrong side which means the chain is running on an angle and not straight.
2001 CBR9290RR; 2003 CBR954RR; 2018 CBR1000RR SP2; 2020 CBR1000RR-R SP on order;
2002 VTR1000 SP-2; 1985 VF1000R; 1985 NS400R; 2018 C125 Super Cub;
2007 MV F4 1000R;
2020 Triumph Daytona Moto 2 Limited Edition
nigelrb is offline
post #3 of 4 Old 06-27-2019, 2:37 PM Thread Starter
Quoted: 4 Post(s)
Thanks for reply but No definitely not, collar spacer on sprocket side plain spacer on brake calliper side, believe me I'm a perfectionist when I know what to do
vesco929 is offline
post #4 of 4 Old 06-27-2019, 3:54 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 388 Post(s)
Reputation Power: 59
Any chance the pitch of the chain isn't matching one of the sprockets? Having a "loose" rear axle/wheel will make some noise, yup.
nigelrb likes this.
unslow1 is offline
