02 954RR Idle surge problem.Any Idea pls - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By Nouf919
post #1 of 2 Old 06-30-2019, 3:05 PM Thread Starter
Quoted: 2 Post(s)
I have 02 954RR that sat for about a year , after having to change the ECM and w/ Horns ,I got the bike to start & running .But now the Idle surge when it's worm , It runs perfect tell the temp goes up then I get the surge .1&2 gear I have to get the rpm 3000 to make it go . new fuel pump , injectors bunch clean & test it , I have 2 map sensors I tried both ,didn't make any difference , & one more thing the Idle screw is not doing anything up or down it doesn't affect the Idle . fuel regulator working correctly , So I have no Idea where to go from there anyone ????? thank you
BigdaddyPaz likes this.
Nouf919 is offline
post #2 of 2 Old 07-01-2019, 12:51 AM
Quoted: 103 Post(s)
Reputation Power: 9
Re: 02 954RR Idle surge problem.Any Idea pls
Check your Fuel pressure regulator. buddies 954 surged a bit when his went bad.
BigdaddyPaz is offline
