954 big bore kit - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 07-01-2019, 1:07 PM Thread Starter
Quoted: 4 Post(s)
954 big bore kit
Hello again guys!
After I disassembled my engine due to lack of oil pressure, I found that cylinder 3 and 4 were burning oil (massive scratches on cylinder walls) and my crankshaft bearings were destroyed.
I am looking at increasing the bore to 76mm instead of the original 75, but does that mean that I have to get the crank balanced to the weight of the new pistons?
Also as this will increase the compression ratio to 13.5:1 from 11.5:1 do I have to get some kind of reinforced head gasket?
What other modifications will I have to be doing?
Any help would be much appreciated!
Dealia is online now
post #2 of 8 Old 07-01-2019, 1:14 PM
nigelrb's Avatar
Quoted: 262 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
Re: 954 big bore kit
Hi, I am not a scientist, but doesn't a larger bore DECREASE the compression ratio?
My reasoning is this: There is a greater cylinder volume, but still the same amount of air/fuel flowing into the chamber. Using the same domed pistons and same size valves means that you now have the same volume of air/fuel being compressed in a larger space. That, to me, gives the effect of 'diluting' the mixture with the consequent LOSS of compression.
2001 CBR9290RR; 2003 CBR954RR; 2018 CBR1000RR SP2; 2020 CBR1000RR-R SP on order;
2002 VTR1000 SP-2; 1985 VF1000R; 1985 NS400R; 2018 C125 Super Cub;
2007 MV F4 1000R;
2020 Triumph Daytona Moto 2 Limited Edition
nigelrb is online now
post #3 of 8 Old 07-01-2019, 1:18 PM Thread Starter
Quoted: 4 Post(s)
Well, to be honest I have no idea. I just red the description from the wiseco kit.
post #4 of 8 Old 07-01-2019, 1:27 PM
nigelrb's Avatar
Quoted: 262 Post(s)
Reputation Power: 7
Hi again.
I'm sure we'll get more input on this during the evening.
I base my thesis on my racing experience from the mid-70s. To illustrate, I bored a CB750 from the original 736cc to 820cc and used CB350 domed pistons as opposed to the flat top 750. (A popular mod in those times) That raised the compression significantly, even with the use of larger valves.
Of course I do not know what is in your Wiseco kit. Perhaps the pistons are 'domed' different than OEM.
2007 MV F4 1000R;
post #5 of 8 Old 07-01-2019, 1:39 PM Thread Starter
Quoted: 4 Post(s)
Thank you!
I do not know if you will get any useful information, but I am looking at these pistons https://www.ebay.com/itm/152165176920
I am guessing that I also will need more fuel sprayed into the cylinders. It would not be a problem if it had a carb as I could just re-jet it, but how do I solve this issue on a FI bike. (this is my first bike with fuel injection)
post #6 of 8 Old 07-01-2019, 3:58 PM
nigelrb's Avatar
Quoted: 262 Post(s)
Reputation Power: 7
Hello again.
I've looked further. Obviously I'm in no position to challenge Wiseco's specs, so we'll assume you get the 13.5 to 1.
I would email Wiseco for advice on head gasket (one with a good copper or similar seal around the ring) and I would also seek advice on perhaps increasing cylinder head torque by a couple of pounds.
http://www.wiseco.com/ProductDetail....02&AppID=24491
2007 MV F4 1000R;
post #7 of 8 Old 07-01-2019, 8:09 PM
Quoted: 749 Post(s)
Reputation Power: 102
@mika_u should be able to answer any 954 overbore question. He was around in June. Wealth of knowledge.
IanDoohan is offline
post #8 of 8 Old 07-02-2019, 3:20 AM Thread Starter
Quoted: 4 Post(s)
Thank you very much guys!
Do you know what modifications I need to do to my fuel delivery system and also are the OEM rods and crankshaft strong enough to be used in this build?
