'02 954 - Where is the negative ground? - Honda Motorcycles - FireBlades.org
 3Likes
  • 3 Post By unslow1
post #1 of 5 Old 07-05-2019, 10:11 AM Thread Starter
Quoted: 16 Post(s)
Hi Guys,
I had a weird problem a few days ago. The bike just died on me at a stoplight. I mean, dead. No lights. No displays. Nothing. It was like I had removed the battery. After a few minutes I got a little power back, but not near enough to get the bike to start. I got the bike home and put the battery on a tender. The battery was at about 11 volts, but it charged up just fine. Now the bike starts and runs normally. The charging system works (14+ volts at mid-rpm). The battery stays at 11 or so during start. So everything seems normal. I'm kinda at a loss, but I wonder if the negative ground is loose or corroded. I see the negative lead disappear under the tank. Where does it go from there? Is it accessible? If not, I may just run a new negative lead to a big frame bolt and see if my problem is fixed. Any other ideas?
Thanks,
Jim Moore
Jim Moore
Jax, FL
JMooreHarrier2 is offline
post #2 of 5 Old 07-05-2019, 11:43 AM
Quoted: 691 Post(s)
Reputation Power: 102
Re: '02 954 - Where is the negative ground?
Originally Posted by JMooreHarrier2 View Post
Hi Guys,
Thanks,
Jim Moore
I cant say 100% for you 954, but I know all the mid/late 90's 900's all grounded from the battery to a starter mounting bolt. So give that a looksee.
My Red Rocker 93 Build Link: Caf 900RRP
IanDoohan is offline
post #3 of 5 Old 07-05-2019, 12:07 PM Thread Starter
Quoted: 16 Post(s)
Thanks. Come to think of it, my 98 CBR600 is the same way.
Jim Moore
Jax, FL
post #4 of 5 Old 07-11-2019, 3:13 PM
Heeza Y Zasch
unslow1's Avatar
Quoted: 386 Post(s)
Reputation Power: 59
...and I've posted this several times. Check the stator/regulator connections (3 wires) as well as the "common" ground next to the battery. One of, or BOTH may have a little bit of this going on
IMG_20161004_164059_zpssdplsb3o.jpg‎
COBRA90GT, IanDoohan and Gunk like this.
unslow1 is offline
post #5 of 5 Old 07-15-2019, 11:26 AM Thread Starter
Quoted: 16 Post(s)
Yikes. I'll keep an eye out for that. As I was playing around with it a day ago I noticed my negative battery connection was a little loose. I tightened it up and everything seems OK. It's going to take a few rides before I completely regain confidence, but I think I found the problem. Thanks for the help, fellas.
Jim Moore
Jax, FL
