954RR, no spark - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 07-22-2019, 8:37 AM Thread Starter
Quoted: 2 Post(s)
954RR, no spark
Okay so yesterday I had no power to the fuel pump...plus lots of other little anomalies. I decided to pull off the wiring harness I was using and swap another one over and now everything works...except now I got no spark. Fuel pump is priming. Injectors are firing (you can smell it). The engine ran the day before I tore it all down. But now I got no spark. As best I can tell everything is plugged in (pulse generator and cam sensor). The tip sensor has been bypassed (red wire to ground). I have tried two kill switch assemblies (both known working). I have tried two key switch assemblies (one known working, one I'm pretty sure works).
Where should I start here?
makenzie71 is offline
post #2 of 4 Old 07-22-2019, 2:29 PM Thread Starter
Quoted: 2 Post(s)
Re: 954RR, no spark
Found it...didn't realize that the harness for the coils looped around the head and back to the main harness.
post #3 of 4 Old 07-22-2019, 11:21 PM
Re: 954RR, no spark
So what was the actual reason? Some connector?
I'm having the same problem with my 954...
Superkaamio is offline
post #4 of 4 Old 07-22-2019, 11:40 PM Thread Starter
Quoted: 2 Post(s)
Re: 954RR, no spark
Yeah, fortunately for me it was just a connector I missed when I swapped harnesses. Off the left side of the head there's a red single conductor plug and then a white (or black I can't recall) four conductor plug. The red one goes to a red plug on the main harness and the white one goes to a plug dangling off the PCM.
