1993 CBR900 Starting Issue, Please Help! - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By nigelrb
post #1 of 6 Old 09-11-2019, 7:01 PM Thread Starter
Quoted: 2 Post(s)
I recently bought a 1993 Fireblade off of Craigslist, has about 30k miles on it, with an engine swap from a '95 in it. Have been riding it everyday, lots of fun, tons of pickup! I was recently riding it down the road, hit a bump, and lost power. I got to the side of the road, put the bike in neutral, and it fired right up. After clunking it into 1st however, the engine would cut out. I assumed right away that it was a kickstand switch failure, and just had the bike towed back to my house where I was thinking I could fix it. That was about 3 weeks ago, I finally had some free time today and tried to bypass the kickstand switch, which I think I did correctly; connected the two green wires, isolated the yellow. As I had the fairings off for the most part already, I figured I would also try my hand at switching out the stock exhaust for a Two Brother's exhaust that also came with the bike. All in all, I swapped out the exhaust, and did what I thought would bypass the kickstand kill switch. I even charged the battery for kicks and giggles! After all that, I put the keys in the ignition, turn it, and nothing happens. The battery is fully charged, and the tank has plenty of gas. Any thoughts or suggestions? I am lost!
Aryk21 is offline
post #2 of 6 Old 09-12-2019, 4:30 PM
Quoted: 657 Post(s)
Reputation Power: 102
Re: 1993 CBR900 Starting Issue, Please Help!
Originally Posted by Aryk21 View Post
I recently bought a 1993 Fireblade off of Craigslist, has about 30k miles on it, with an engine swap from a '95 in it. After all that, I put the keys in the ignition, turn it, and nothing happens. The battery is fully charged
When you say nothing happens, what exactly? No lights, no starter, no nothing? And what does fully charged mean to you? A fully charged battery should read 12.7vdc static (no load or connections). Put a meter on the battery and turn the key on. What happens? Does the voltage drop?
Check your regulator/rectifier and stator connections. Are they melted? Also check your 30a main fuse and connector.
IanDoohan is offline
post #3 of 6 Old 09-13-2019, 12:00 AM Thread Starter
Quoted: 2 Post(s)
Yeah, no lights on dash, no starter, no nothing! However, I did hook up a battery tester to the battery today like suggested, and the battery was only reading around 4.6v. Did not test what would happen if I turned the key. Maybe try a jump start?
Aryk21 is offline
post #4 of 6 Old 09-13-2019, 4:26 PM
Quoted: 657 Post(s)
4.6 is beyond bad. You can hook jumper cables from your car, just make sure the car IS NOT running. Make sure your main fuse is good.
post #5 of 6 Old 09-14-2019, 2:25 AM
nigelrb's Avatar
Quoted: 130 Post(s)
Reputation Power: 6
Send a message via Skype™ to nigelrb
Originally Posted by IanDoohan View Post
. . .You can hook jumper cables from your car, just make sure the car IS NOT running. . .
As a point of interest, why do you say that, Ian. Might it be to keep the current a bit lower?
IanDoohan likes this.
2018 CBR1000RR SP2 / 2004 CBR1000RR / 2003 CBR954RR / 2001 CBR929RR (Erion Racing Edition)
1985 Honda VF1000R / 1985 Honda NS400R
2007 MV F4 1000R / 2020 Daytona 765 Moto 2 Replica (on order)
nigelrb is offline
post #6 of 6 Old 09-14-2019, 4:59 PM
Quoted: 657 Post(s)
Yes, the output from a cars alternator is substantially more than what our little bike’s battery and wiring can handle, although 12 volts is 12 volts, I would expect the current to be much higher to keep a cars battery at capacity. You run the risk of frying stuff is all. The huge battery from the car holds enough juice to jump the bike easily on its own.
