954 non start after transmission change - Honda Motorcycles - FireBlades.org
 3Likes
  • 3 Post By 954rryoujoking
post #1 of 3 Old 09-14-2019, 3:36 PM Thread Starter
Hello anyone reading this, i need help pleease. Ok so the bike was running perfectly before removing the engine for a transmission change. New gearbox in, engine all back together and in the bike, no unplugged connectors anywhere, only thing unplugged is i believe a drain pipe the skinny one attached to fuel tank.
Fuel tank primes, bike turns over fine, has a strong battery, fuses good, pc3 connected or not doesnt matter. Spraying brake cleaner into throttle bodies still wont start it so i assume its missing a spark for some reason. Im completely stumpped so any help would be appreciated thank you
954rryoujoking is offline
post #2 of 3 Old 09-15-2019, 5:45 PM
Quoted: 696 Post(s)
Reputation Power: 102
Re: 954 non start after transmission change
Typically on a rebuild like that there will undoubtedly be a connector either not connected, or connected to the wrong connector. Give it a more detailed look over. Also, if there was a failure of a sensor, you would probably get a code you could decipher through the dash MIL light
My Red Rocker 93 Build Link: Cafť 900RRP
IanDoohan is offline
post #3 of 3 Old 09-15-2019, 5:54 PM Thread Starter
Thanks for the reply, went to the bike this morning and she started straight away but then suddenly stopped again. After hours of checking everything, i found one cam sensor wire corroded in the connector. Was working fine before the strip down but i guess the contact just wasnt right after. Grrrrr 🤣
unslow1, IanDoohan and nigelrb like this.
