06-07 Flywheel and Stator on 04 - Honda Motorcycles - FireBlades.org
 3Likes
  • 1 Post By Johncocktoasten
  • 1 Post By tdeal28
post #1 of 6 Old 10-12-2019, 9:34 PM Thread Starter
Quoted: 3 Post(s)
Having charging issues with 04. OEM Fywheel and Stator is not available anymore. Do the 06-07 parts fit the 04? Has anyone done this?
Johncocktoasten is offline
post #2 of 6 Old 10-12-2019, 10:45 PM
Quoted: 759 Post(s)
Reputation Power: 102
Re: 06-07 Flywheel and Stator on 04
Hey Fletch,
Looks like the part numbers are different, but only the last 3 which usually only means a vendor change, not a fitment change. It is possible that they would fit. I have no experience with it, but hopefully someone will know and chime in. You may want to try a dedicated 1k site, maybe @nigelrb will know someone.
IanDoohan is offline
post #3 of 6 Old 10-12-2019, 11:10 PM Thread Starter
Quoted: 3 Post(s)
IanDoohan,
Thank you for the input. I know these bikes had Stator issues but in the 12 years and 28k miles I never had a problem until last year. I burnt up the cheap aftermarket Stator I put in last week. I also love the fact you got my name reference from the Fletch movies. Thanks again for the help!
IanDoohan likes this.
post #4 of 6 Old 10-12-2019, 11:29 PM
Quoted: 759 Post(s)
IanDoohan,
Igor Stravinski (twice removed cousin of Nugent, Ted Nugent) once sad that ebay stators are usually junk, but the reg/rec can toast stators as well.
I'm not as up to speed on the newer bikes, but it's not just a 1k problem. Honda has inherently had stator, reg/rec, and related connector issues since they went to the stator/flywheel design. The 93-95 900RR's were all the same, then with basically the same motor the 96-99 900's changed the size of the flywheel and stator and cover to not work on the older bikes.
That all being said, I have 2 Rick's Stators on my 93 and 99 900's 2 years and no problems. BUT, I also changed my reg/rec's on both to the larger, MOSFET units from reputable company in Missouri.....or Michigan. I can't remember. Either way, doable aftermarket stuff is out there.
Good Luck
post #5 of 6 Old 10-12-2019, 11:44 PM Thread Starter
Quoted: 3 Post(s)
A lot of useful information, I really appreciate it. I’ll tell Mr. Underhill you said hi next time I see him.
post #6 of 6 Old 10-29-2019, 4:02 AM
Quoted: 2 Post(s)
So, I just picked up a 2005 CBR1000RR with low miles to which the original owner never had the flywheel and Stator replaced. Prior to buying I researched this greatly and made some phone calls due to the 2004-05 part numbers showing unavailable. The answer is YES, the 2006-07 parts will bolt right up and work.
Southern Honda Powersports actually lists the same part numbers for all 2004-2007 models and Rick's Stators specifically state that they will not warranty their stator unless you have upgraded the flywheel to a 2006-07. I provided the links so you don't have to take my word for it haha..
https://parts.southernhonda.com/a/Ho...MEL3E0900.html
https://ricksmotorsportelectrics.com...-Stator-21_118
tdeal28 is offline
