Honda 2000 929 Dash board out and lights very Dim - Honda Motorcycles - FireBlades.org
 6Likes
  • 1 Post By cwa1521
  • 1 Post By IanDoohan
  • 1 Post By nigelrb
  • 1 Post By nigelrb
  • 1 Post By machinehead
post #1 of 8 Old 11-22-2019, 3:28 PM Thread Starter
Can anyone tell me what this part is with the Green wires running to it? to me, it seems like a grounding terminal. my dash lights won't show and my head lights are Dim. As you can see in the pics I have a lot of corrosion on this part. I was going to cut all the wires out of the terminal and solder them together. do you think this will fix my problem? if not does anyone have the fix?
pic 1.jpg‎   pic 2.jpg‎   pic 3.jpg‎
IanDoohan likes this.
cwa1521 is offline
post #2 of 8 Old 11-23-2019, 8:46 PM
Quoted: 717 Post(s)
Reputation Power: 102
Re: Honda 2000 929 Dash board out and lights very Dim
Typical problem on the 929. It is a ground block, and will wreak havoc on your electrical system when it corrodes like that. If you can't salvage the block itself, cutting and combining the wires is your next logical step .
Let us know how it goes.
nigelrb likes this.
IanDoohan is offline
post #3 of 8 Old 11-24-2019, 6:11 AM
nigelrb's Avatar
Quoted: 212 Post(s)
Reputation Power: 7
Send a message via Skype™ to nigelrb
Cheers, Ian. My first thought was a short of some type - pure sign of dimming lights - but I had nowehere near the knowledge to pinpoint exactly as you have done. @cwa1521 should be up and running very quick!
2020 CBR1000RR-R SP (on order) / 2018 CBR1000RR SP2 / 2003 CBR954RR / 2001 CBR929RR (Erion Racing Edition)
1985 Honda VF1000R / 1985 Honda NS400R
2007 MV F4 1000R / 2020 Daytona 765 Moto 2 Replica (on order)
nigelrb is offline
post #4 of 8 Old 11-24-2019, 11:04 AM
Quoted: 717 Post(s)
First modern Honda that I know of with the ground block like that. It’s up behind the dash and out of sight. “Well used/abused” 929’s usually fall victim to it. I would imagine a clean 929 such as yours should be good, but I suspect that it can get too hot when charging issues arise. Give yours a look just to gauge its current state.
Your 954 will have 1 or 2 of them as well. I think the 954 is under the seat but not sure.
nigelrb likes this.
post #5 of 8 Old 11-24-2019, 11:27 AM
nigelrb's Avatar
Quoted: 212 Post(s)
Reputation Power: 7
Originally Posted by IanDoohan View Post
. . . Give yours a look just to gauge its current state.
Erm, mine doesn't get ridden enough to charge!
(On tender all the time though - I have 7 of them sapping UK's national power grid!)
nigelrb is offline
post #6 of 8 Old 11-24-2019, 11:53 AM
Quoted: 30 Post(s)
there is this one in the loom too... this has several earths and also power to the coils and injectors, amongst other things (green = earths, Black/White = switched 12v power).
IMG_3595.JPG‎   IMG_3596.JPG‎   IMG_3597.JPG‎
thistintivin likes this.
machinehead is offline
post #7 of 8 Old 11-29-2019, 6:10 AM
Quoted: 2 Post(s)
Wow, this would go along way in assisting others in the same problem.
thistintivin is offline
post #8 of 8 Old 11-29-2019, 11:23 AM
nigelrb's Avatar
Quoted: 212 Post(s)
Reputation Power: 7
True. Not too many posts on this forum, but questions raised generally get prompt, correct advice - especially if the query is about the 'carb' Blades.
nigelrb is offline
