lowering temp. on a 954 - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 06-09-2003, 10:02 AM Thread Starter
Re: lowering temp. on a 954
Hi everyone. Does anyone have any information on lowering the temperature on a 954? Can the thermostat be changed to run 20-30 degrees F. colder? I think this would be another way to make some gains or am I wrong? Got any ideas? Thanks!
larddog954 is offline
post #2 of 7 Old 06-09-2003, 1:49 PM
I've heard some people talking about running Water Wetter before, but haven't tried it myself. Don't know how much cooler it'll make her run though.
Pulse is offline
post #3 of 7 Old 06-09-2003, 1:53 PM
I have Watter Wetter in my bike but only because it was required for the track. I can say that I noticed the bike ran cooler, at least cooler than I expected in FL when the temps were in the mid 90's.
Can't say that it runs 20 or more degrees cooler, though.
HondaGal is offline
post #4 of 7 Old 06-09-2003, 4:07 PM
larddog954 : Hi everyone. *Does anyone have any information on lowering the temperature on a 954? *Can the thermostat be changed to run 20-30 degrees F. colder? *I think this would be another way to make some gains or am I wrong? *Got any ideas? *Thanks!
I was running evans coolant in my track F3 and it would run around 203 when riding hard. I put water wetter in it and it's now running around 185-189.
RRWANTR is offline
post #5 of 7 Old 06-09-2003, 4:50 PM Thread Starter
Do you have to drain your radiator to use water wetter? How do you use it?
post #6 of 7 Old 06-09-2003, 4:54 PM
The instructions are on the bottle, but in the meantime...
Yes, the idea is to drain all of the coolant from your bike, and replace it with distilled water. *The name 'Water Wetter' is a play on the idea that Water Wetter will make your distilled water 'more wet.' You add a small amount of Water Wetter to act as a lubricant for rubber seals and for anti-corrosion. *You need to use caution in the winter, and replace the water/Water Wetter with anti-freeze if your bike will be subjected to freezing temps.
Pete is offline
post #7 of 7 Old 06-10-2003, 11:13 AM Thread Starter
Thanks for all the info on water wetter. I am going to give that a go....I am still curious about a thermostat change. I think I read somewhere that for every 5 dergrees F. cooler your bike runs you gain 1 HP. Is that right?
954 shock for 929?, other "better" OEM? 2bitsamile Honda FireBlade 2 12-01-2003 8:36 PM
954 fork spring rate Proto Honda FireBlade 11 08-05-2003 8:12 PM
Dyno'd the 954 K9inAZ Honda FireBlade 9 07-19-2003 3:57 AM
performance parts for the 954 gb506 Honda FireBlade 1 07-10-2003 12:59 PM
