bogging down low with full exhaust? - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 04-29-2004, 7:32 PM Thread Starter
is this normal? i have a full exhaust with the correct map from the PC website. i feel like i am towing something when i am stopped and starting to go up to about 2200 rpm. this will suck for round town driving...
jerseydrew is offline
post #2 of 16 Old 04-29-2004, 7:37 PM
nedro's Avatar
Reputation Power: 27
Re: bogging down low with full exhaust?
Is it worse than before?
Ride Red
nedro is offline
post #3 of 16 Old 04-29-2004, 9:43 PM
Reputation Power: 17
my 954 does the same thing and so did my 929. You just have to give her a little more juice from the start and use a little more clutch. You'll get used to it.
Uncle Jesse is offline
post #4 of 16 Old 04-29-2004, 9:53 PM
Huh? A little more juice? No no no . It's the fueling. I don't care what you downloaded from where, but the fueling is either too rich (best bet) or too lean at those points. Get a custom map written for it, and the problem will go away.
The Sook is offline
post #5 of 16 Old 04-29-2004, 10:01 PM
No, it might not.(full erion, two custom maps made at an Dj approved site, with a 250 dyno and tuning link)
risc32 is offline
post #6 of 16 Old 04-29-2004, 10:27 PM
HondaGalToo's Avatar
Reputation Power: 31
Sook's right. A custom map probably will help.
HondaGalToo is offline
post #7 of 16 Old 04-29-2004, 10:33 PM
What he said.
Although depending upon the system there may always be a bit of a loss down low even with a custom map.
01 CBR 929
08 Ducati 1098
Florida Trackdays
GiveGab
fl-929 is offline
post #8 of 16 Old 04-30-2004, 12:22 AM
I have a feeling I have the same problem with my full erion system, but then again, I have never ridden my bike without an exhaust (came with when I bought). But I got used to it really quick, and it wasn't that bad for me. But it might not be as bad as yours is???
c_reber is offline
post #9 of 16 Old 04-30-2004, 12:32 AM
Mine bogged alot when I put the pipe on w/o the PC but after installing the PC cleared it right up, not using the right map at the moment but it still seems to run mint.
MrX954 is offline
post #10 of 16 Old 04-30-2004, 12:42 AM
Putting a 15 tooth front on or going up a couple in the rearwill help a lot if the tuning is as good as it's going to get.
OntheEdge is offline
post #11 of 16 Old 04-30-2004, 7:56 PM Thread Starter
it is really wierd to drive now. it is difficult to run around town like this. but once i am over 2200rpm WOW it is beautiful!i guess i need to get some loot together and get a custom map.....
post #12 of 16 Old 04-30-2004, 8:12 PM
I'm using a full hindle without a PC3 and on my 929, and I haven't noticed any change down low. I always give it a lot of gas in first, though.
brian48130 is offline
post #13 of 16 Old 05-01-2004, 1:23 PM
nedro's Avatar
Something's wrong. My 929 never acted like that exept when the bike was running too rich down low, just after installing the Micron without a custom map.
Ride Red
nedro is offline
post #14 of 16 Old 05-01-2004, 2:33 PM
Dan Kyle has a few charts of the Erion system on a 929 showing a 13 HP loss between 2000 and 4000 rpm (along with an 8 HP loss between 5 and 8) aginst the STOCK system. After custom mapping the loss on the low end was still over 10 HP in the same range. It appears from looking at these charts that the Erion is definitely optimized for top end only.
abtech is offline
post #15 of 16 Old 05-01-2004, 10:48 PM
YEAH? That's fukt. The Arata system even not mapped doesn't give that sort of loss, even the Serpent which gives what I think is a big dip (un mapped) isn't that bad. Wow. Why the hell would you buy one then?
The Sook is offline
929 Noise b/t 3k and 4k after full exhaust FastLane929 Honda FireBlade 17 01-09-2011 3:32 AM
full exhaust vs. bolt on jerseydrew Honda FireBlade 18 03-07-2004 9:14 PM
Correct Jetting for CBR f2 with full exhaust? Pater Honda CBR 600 4 01-11-2004 8:00 PM
