Anyone gutted a stock 929/54 can ? - Honda Motorcycles - FireBlades.org
post #1 of 8 Old 05-05-2004, 9:56 PM Thread Starter
If so, how does it sound and run? I'm looking for a bit more growl and maybe some power (certainly not a loss of) for cheap. And I can't think of anything cheaper than hacking up the stocker.
Thanks
replica is offline
post #2 of 8 Old 05-05-2004, 10:09 PM
Re: Anyone gutted a stock 929/54 can ?
Mine was welded on the back so you couldnt get into it. And when I looked down from the midpipe side there are a few different chambers that the flow goes through. It wasnt straight through like my hindle. The Hindle is WAY lighter too.
Smitty929RR is offline
post #3 of 8 Old 05-05-2004, 10:13 PM
There is more to making a pipe than just gutting a standard one. In the same way as 5 different pipes will give you 5 different results. Just see if you can get a 2nd hand after market pipe. Don't gut the stocker. It'll be crap.
The Sook is offline
post #4 of 8 Old 05-06-2004, 12:04 PM
I removed the main baffle plate.If you look in from the bolt on side there is a plate that you can reach with a looooong drill bit.I haven't been able to remove the other baffle tubes that appear to be in there,looks like it would require major surgery.I like the way it sounds,definately better than stock.I highly doubt I gained or lossed any hp.I do have an extra 929 can with this mod already done for $20 since I ended up doing the same mod to a 954 can.If you want to hear it,we can exchange phone #'s and I can bounce it off the limiter for for you.
jafo is offline
post #5 of 8 Old 05-06-2004, 12:55 PM
Settle down Steg....
slowpoke is offline
post #6 of 8 Old 05-06-2004, 1:33 PM
He does have 2 of the most memorable threads,stinky roommate and 11k rpm.I can only hope to have his fame 1 day.
jafo is offline
post #7 of 8 Old 05-06-2004, 3:35 PM
Amen.
You're just as likely to make the bike sound like a UPS truck as you are to improve the sound. Just leave the darn thing alone if you can't afford a s/o.
Chain is offline
post #8 of 8 Old 05-06-2004, 8:05 PM
I have a rashed stocker you can have for free. Hack it up all you want and see if you like it. PM me if you want it.
Denny is offline
Need stock 954 measurements please.... gerry Honda FireBlade 4 05-08-2004 10:15 AM
PowerCommander to a stock 929? vma Honda FireBlade 4 03-05-2004 5:16 PM
AMA says stock TB for multi cylinders deez Road Racing: Professional 13 08-18-2003 8:47 PM
PCIII Maps for stock CBR 954 Joelorama Honda FireBlade 1 06-26-2003 9:34 PM
