Steering stem nut install question - Honda Motorcycles - FireBlades.org
post #1 of 20 Old 05-16-2004, 5:38 PM Thread Starter
I'm new to the forum and I've already discovered the wealth of knowledge Fireblades.org presents. However, I did a search and couldn't find a definitive answer.
Question: I just installed a Hyperpro RSC steering damper. When installing the steering stem nut on top of the bracket supplied by Hyperpro and tightening to 76 ft/lbs torque, I don't have a full set of threads. This makes me nervous. Is this normal for this steering damper setup? Or should I not worry about this at all? Do I have the wrong install kit? My bike has had the 2002 steering stem/bearing recall done and wonder if this could be the problem. Thanks in advance for services rendered.
PHARMER954 is offline
post #2 of 20 Old 05-17-2004, 12:25 AM
Reputation Power: 19
Re: Steering stem nut install question
Are you using the original washer under that nut. Because I don't think you're suppose to use it with the hyperpro bracket. I had one at one time but have the Ohlins now. I liked the Hyperpro better as far as function.
OntheEdge is offline
post #3 of 20 Old 05-17-2004, 12:31 PM Thread Starter
I am not using any washer at all (per instructions by hyperpro). The hyperpro bracket is the "washer" in this case. Should I use blue loctite on it to make sure it does'nt loosen?
post #4 of 20 Old 05-17-2004, 1:20 PM
HondaGalToo's Avatar
Reputation Power: 32
I have a Hyper Pro damper also (the older model). The nut, when properly torqued, has about 1-2 rows of thread showing above the bolt it's screwed onto. Is that what yours has? I think it looked that way stock, too, as the washer was under there instead of the Hyper Pro bracket. If you're only showing a line or two of threads on the nut, I think that's normal. The bolts on the steering stem usually don't come up above the nut.
HondaGalToo is offline
post #5 of 20 Old 05-17-2004, 1:24 PM
crazycuRRie's Avatar
Send a message via MSN to crazycuRRie
Can you get us any pictures of the install, i know that my ohlins brackt does not allow for OEM washer either and i have 1 1/2 - 2 full threads showing..
WSMC 954
Sponsor: Mach 1,Chicken Hawk Racing, LP USA, Suzuki Motor Corp.
crazycuRRie is offline
post #6 of 20 Old 05-17-2004, 1:27 PM
Kind of related, I just installed a ohlins damper. The bracket that goes on the steering stem has a "peg" that comes out of it to lock it into place. Well when I was tightening it, that peg bent and began to shift...scratching the hell out of my stem. What a piece of crap design. Looking at it, the entire damper will fail if that peg doesn't hold up...which it didn't hold up against a torque wrench. I'm going to grab a tig welder and do this thing up right. Anyone else have a similar experience. (Sorry, didn't mean to jack your thread)
jcblitz is offline
post #7 of 20 Old 05-17-2004, 2:11 PM Thread Starter
I'll get some pictures tonight when I am home, but I'm thinking it has about 4 rows of threads showing. Sounds like from the replies so far, this is normal? I know the tab on the hyperpro bracket is in the slot on the back of the upper triple clamp.
post #8 of 20 Old 05-18-2004, 1:38 AM
I installed mine and havent had the steering bearing recall done. No washer installed and no threads are showing...
To the one with the Ohlins damper: did it come with some kind of grease to install between the nut and the bracket?
Dookie is offline
post #9 of 20 Old 05-18-2004, 1:51 AM
I had the same problem with my Hyperpro mount and had to buy a new one. I got the Harris mount for my Ohlins and it's designed much better.
post #10 of 20 Old 05-18-2004, 10:00 AM
I went to an autoparts store and bought a package of rolling pins. I tapped out the bent peg and stuck a new one in. I had 2 people holding that bracket steady with all their might as I torqued it. What a crappy design.
jcblitz is offline
post #11 of 20 Old 05-18-2004, 11:09 AM Thread Starter
Here is the picture I promised. Just got an e-mail from hyperpro themselves. They said 2.5 mm below the steering stem shaft is normal and nothing to worry about. This sounds about what I have. I will attach their e-mail for everyone to view.
post #12 of 20 Old 05-18-2004, 11:12 AM Thread Starter
ooops! invalid file type I guess. I'll do it when I get home. Here is the e-mail:
This is the reply from R&D, probably says it best...
according to my data the nut should fall short 2.5mm of thread. This is correct. The thickness of the bottom of the bracket is 3.5mm, the nut is 12mm thick, which adds up to 15.5mm. The steering stem is raised only 13mm above the top triple tree, so that explains the 2.5mm thread-loss. If the difference is more than 3mm please let me know.
We've tested this succesfully in development and have been selling over a thousand of this type of kit for 4 years (the 2000/2001 CBR929RR has the same issue) without any problems concerning this. In other words, no need to worry.
Let us know if you have any other questions...
Hyperpro USA
1-888-963-1212
post #13 of 20 Old 05-18-2004, 12:30 PM
CBRBob's Avatar
It seems like we (including me) agree that a thread or 2 sticking up is correct. Only jc deems it a crappy design. The instructons do tell you to keep the tab in place and use the supplied grease on the surface of the bracket and nut so it won't drag so it won't turn. Also, it's not the tab that keeps the damper in place, its the clamping force from the nut. The tab is supposed to keep it straight during install.
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #14 of 20 Old 05-18-2004, 1:52 PM
I'm talking about the ohlins kit, I haven't seen the hyperpro kit. The ohlins kit comes with a new nut with less threads, so that wasn't my issue. Ohlins does not have grease and here are the instructions right from the manual:
Loosen the centre nut of the steering column. Fit
the bracket arm (02270-04) supplied. The bracket
should be facing backwards so it locks in the groove
of the triple clamp. Fix the bracket with the centre
nut supplied. Thighten to a torque of 100 Nm.
That peg needs to with stand the 100Nm's of torque, which it hasn't time and time again...from my experience and others.
jcblitz is offline
post #15 of 20 Old 05-18-2004, 3:12 PM
Chiming in late here - but my RSC Hyperpro damper is exactly as you have described - so it's apparently normal. I have been retorquing mine occasionally just to be safe. No probs so far.
Let's see some of those 250R's.
johnnycrash is offline
Galfer line install question SuperDave Honda FireBlade 41 10-02-2007 8:43 PM
Cleaning steering stem? MedTechRR Honda FireBlade 16 03-05-2004 10:42 AM
Toby steering damper hardware question smokinjoce Honda FireBlade 2 02-24-2004 1:01 PM
Steering Stem Nut TraumaOne Honda FireBlade 6 12-23-2003 9:51 PM
Lap timer install Mattress Riding Gear / Luggage 9 08-20-2003 1:17 PM
