929 gauge housing broke- use 954 gauges or replace housing? - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 05-26-2004, 3:39 AM Thread Starter
107
I dropped my bike going around a corner at about 40mph 2 weeks ago, caused a lot of damage to the front upper fairing area- the brackets that hold the fairing and gauge cluster got bent and snapped the tabs off on my gauge.
The gauge still works fine so I was wondering if it's possible to buy a new/aftermarket housing somewhere rather than replace the whole thing? If not, would I be able to put the 954 style setup on mine? I think the functions are all the same but I like the way it looks.
Thanks,
-P.J
107 is offline
post #2 of 6 Old 05-26-2004, 9:16 AM
EatnAsphalt's Avatar
Reputation Power: 19
Re: 929 gauge housing broke- use 954 gauges or replace housing?
Know anyone with a 954 that would let you pull the gauge cluster and see? No way of knowing if the plug from the harness is the same without having both.
EatnAsphalt is offline
post #3 of 6 Old 05-26-2004, 10:01 AM
They are not interchangeable, different connectors and mounts.
Cowboy is offline
post #4 of 6 Old 05-26-2004, 9:21 PM
Thanks,
-P.J
i dont think you need those tabs ... just use the bolt through it and it will be tight enough to do the job
FullForce is offline
post #5 of 6 Old 05-27-2004, 3:09 AM Thread Starter
107
Yeah if the part where the bolt goes were completely intact I think that would work. Problem is that part of that broke too- if the tabs were okay it would definately hold but I wouldn't be so sure without them(I could probably ghetto- rig it but that's my bike I'm talking about!).
I guess there's no chance at just getting the housing and not the internals? I like the idea of not having to explain the mileage when I sell the bike- unless someone has a used gauge with exactly 4700 miles on it!
107 is offline
post #6 of 6 Old 05-27-2004, 9:26 PM
i would epoxy the tabs back on ... chit on paying that kinda dough for a good working piece
100,000 kms on a 929 omen137 Honda FireBlade 20 10-08-2004 1:21 PM
will 954 can fit 929? 2bitsamile Honda FireBlade 2 02-23-2004 2:45 PM
954 shock for 929?, other "better" OEM? 2bitsamile Honda FireBlade 2 12-01-2003 8:36 PM
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 8:27 PM
