Fork Springs - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 06-22-2004, 1:38 AM Thread Starter
Fork Springs
I'm going to be needing stiffer springs up front on the 1000RR.. Now usually I prefer to do most of the mechanical work myself and consider myself fairly mechanically competent, but I've never opened up a set of forks --heard some bad stories of failed revalving attempts, so would just send forks off to be worked on..
I'm debating on weather to change the springs myself, as I don't intend to change the valves at this point, I'd rather not pull the tubes and send them off, especially if I can simply/quickly/cheaply replace the springs without removing the forks.. --Any advice would be appreciated..
jnonny is offline
post #2 of 4 Old 06-22-2004, 2:15 AM
Re: Fork Springs
It is not that bad. Here is a link that is for an Aprilia, but the procedure is the same.
http://www.geocities.com/sl_mille/springs.html
Ernie
Ernie is offline
post #3 of 4 Old 06-22-2004, 8:41 AM
CBRBob's Avatar
Re: Fork Springs
You can change the springs with the forks on the bike! It helps if you have a stand that holds the bike under the triple clamps but not 100% necessary. You will need to measure some to determine preload and perhaps cut the spacer but thats it!
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #4 of 4 Old 06-24-2004, 12:42 PM Thread Starter
Re: Fork Springs
Thanks for the feedback.. The whole "special tool required" thing kinda makes me think twice.. but then again, I might just be looking for an excuse to send out the forks and revalve them since they would allready be off the bike and at the shop anyway .. --So now I'm contemplating spending the extra $$$ for revalving..
jnonny is offline
New 929 Fork Springs? rockets25 Honda FireBlade 1 05-13-2004 11:52 PM
Changes to damping after changing fork springs ? mickyboy Honda FireBlade 16 02-09-2004 5:41 AM
Bike Handles Like Ass GoatRacer Honda FireBlade 22 10-17-2003 6:14 PM
New fork springs CBRjack Honda FireBlade 28 07-17-2003 7:00 PM
Where to get fork springs? Denny Honda FireBlade 21 07-05-2003 12:29 PM
