Need a quick answer - Ohlins damper install, 954 - Honda Motorcycles - FireBlades.org
post #1 of 16 Old 06-22-2004, 4:28 PM Thread Starter
soon2b954's Avatar
What's the best way to torque the steering stem nut without bending/breaking the soft aluminum pin? Also, what bolts should I use the blue loctite on?
TIA
soon2b954 is offline
post #2 of 16 Old 06-22-2004, 8:46 PM Thread Starter
soon2b954's Avatar
Re: Need a quick answer - Ohlins damper install, 954
Well I torqued the steering stem nut to 76ftlbs and what do you know, I bent the pin!!
Also the damper seems to move up and down (front to back) I have the bolt going into the sleeve then the metal washer and finally the teflon spacer.
post #3 of 16 Old 06-22-2004, 8:48 PM
It's supposed to swivel/roll, if that's what you mean.
ConqSoft is offline
post #4 of 16 Old 06-22-2004, 8:51 PM
I ended up using a hardened sheared-off drill bit in place of the factory pin. Even then I wasn't happy with that mounting arrangement. They should've included a little lip, or at least a better support, in the mounting bracket.
The movement you're describing is normal.
2OHOH2 is offline
post #5 of 16 Old 06-22-2004, 8:56 PM Thread Starter
soon2b954's Avatar
Just the bracket assy (in the centre) moves up and down.
post #6 of 16 Old 06-22-2004, 9:02 PM Thread Starter
soon2b954's Avatar
Seems like a poor design, how do the expect you to keep the bracket straight when your using 76ftlbs of torque!! I'm sure the next time I take it off and retighten it the pin will snap.
Seems to be quite a bit of movement though!!
post #7 of 16 Old 06-22-2004, 9:46 PM
Ooook, wait a sec. What's moving, exactly?
The bracket that mounts underneath the stem nut?
The bracket that attaches to the frame through the tank?
The clamp that holds the damper to the other two?
The damper itself?
2OHOH2 is offline
post #8 of 16 Old 06-22-2004, 9:52 PM Thread Starter
soon2b954's Avatar
The clamp that holds the damper to the other two? This one
The damper itself?
When you look from the side you can see light passing through the bigger part of the damper (closest to the tank)
post #9 of 16 Old 06-22-2004, 9:58 PM
OK. So it's the metal piece that clamps around the damper itself.
Now, once you've tightened the two allen screws that hold the damper in the clamp, does the damper still move, or does the entire set (damper and clamp) move as one?
The space is normal, by the way: http://www.kyleusa.com/catalog/ohlin...er_1224435.htm
2OHOH2 is offline
post #10 of 16 Old 06-22-2004, 10:03 PM Thread Starter
soon2b954's Avatar
Thanks, yes the entrie set damper/clamp move up and down together.
post #11 of 16 Old 06-22-2004, 10:12 PM
Then it is the normal movement that Conq and I had mentioned, but just to be absolutely certain, make sure that the order in which you use your washers is correct, other than that, it's all good.
2OHOH2 is offline
post #12 of 16 Old 06-22-2004, 10:52 PM
This works for me every time....
Be sure to degrease all the contact parts. When placing the final nut smear a VERY small amount of grease on the bottom of the nut only and torque just to spec. This will keep the nut from dragging the Ohlins bracket out of position. Lead based antiseeze or assembly lube is good. Use VERY little. If there is any lube BELOW the bracket this won't work right.
Speedfreek is offline
post #13 of 16 Old 06-22-2004, 10:58 PM
Did you try to torque in thirds? 26ftlbs, 52ftlbs, 76ftlbs
n0xiu1 is offline
post #14 of 16 Old 06-22-2004, 11:19 PM
crazycuRRie's Avatar
Reputation Power: 17
Send a message via MSN to crazycuRRie
Freeplay is normal in the up and down direction When i take mine off and on i actually pul the bracket back towards me to give it some leverage, after several R/R the pin is still perfectly straight
WSMC 954
Sponsor: Mach 1,Chicken Hawk Racing, LP USA, Suzuki Motor Corp.
crazycuRRie is offline
post #15 of 16 Old 06-22-2004, 11:32 PM
I did the same thing with the drill bit. It doesn't bend a bit.
Northy is offline
Pictures of my Hotbodies Undertail + UFO install in 2003 954. ClemsonJeeper Honda FireBlade 22 07-08-2004 5:34 PM
Damper on 954 RPinOZ Honda FireBlade 13 05-19-2004 7:36 PM
Ohlins install soon2b954 Honda FireBlade 3 03-11-2004 8:30 PM
