Damaged Case and Case Cover (CBR929) - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 06-30-2004, 2:28 AM Thread Starter
Can this be repaired (Welding) and purchasing a new case cover?
DSC00011.JPG‎   DSC00005.JPG‎   DSC00006.JPG‎
HiTech202 is offline
post #2 of 23 Old 06-30-2004, 6:28 AM
Re: Damaged Case and Case Cover (CBR929)
Yes, i think so. If you find the right person to do the job.
This is a "standard" Firebladeproblem when crashing on the left side of the bike. Very common problem if your using your bike on the track. At least here i Sweden.
TheKing is offline
post #3 of 23 Old 06-30-2004, 11:41 AM
Wow the case looks pretty bad, I replaced mine a couple months ago too but it only had a small hariline crack on the bottom which was leaking oil, nothing else was damaged. dunno bout welding it though. I'd buy a new cover, they are so delicate but some companies have made tougher ones but cant remember the name, just do a search and you will find it. Good luck
JWHT is offline
post #4 of 23 Old 06-30-2004, 1:31 PM
He's not asking about welding the cover. If you look, the engine case itself has broken away.
Sirkbac is offline
post #5 of 23 Old 06-30-2004, 1:43 PM Thread Starter
Sirkbac, your right. Maybe I didn't explain it well and should have provided more pics. I know the case cover can be replaced, but being as though I have the small portion of the engine case, can that be welded?
DSC00010.JPG‎   DSC00007.JPG‎
post #6 of 23 Old 06-30-2004, 5:31 PM
whoa that last pix look bad, it look like there a chuck that came off the engine case, your probably gonna need to get it welded, i had a small lil hair line crack on mind too, i use jb weld as a temp solution till i get it welded
DizwikedCBR is offline
post #7 of 23 Old 06-30-2004, 10:15 PM
Ohhhh, I see! Now I get it, I looked at the 2nd pics more and ya maybe a good welding shop can weld that back together. Make sure you get good references from the shop for their work before you let them tackle it. That really looks bad though, don't mind if I ask you how it happened??? I know you probably had the bike slide on its side for awhile for it to crack like that. Engine case is aluminum right? If so it can be done but has to be done properly as i've heard of people welding cracks on aluminum cylinder heads with no troubles.
JWHT is offline
post #8 of 23 Old 07-01-2004, 1:07 AM
Thank god Iím not the only one this happened too. I skipped the welding and purchased a used motor on eBay. Local dealer quoted me 3400 to replace the crank case, fluids and gaskets. Still have the engine and can still strip if needed. I figured this was the quickest and painless way to resolve issue.
New954RRider is offline
post #9 of 23 Old 07-01-2004, 1:24 AM Thread Starter
This is my friends bike. He let his cousin ride it and he dropped it. I think he said the case hit the curb.
post #10 of 23 Old 07-01-2004, 10:51 PM
thats the same way i damaged my bike...DAMN CURB!!!
post #11 of 23 Old 06-07-2005, 8:26 AM
WOW!!! this happened to me as well!!! Mine isnt as bad. a guy here says he can weld it. what did you do in the end?
resist1 is offline
post #12 of 23 Old 06-07-2005, 10:01 AM
Reputation Power: 15
****, that sucks. Hopefully it can be welded.
One way to prevent damage is here
can't keep them on at the track, because they can hit the ground at extream lean angles. But they are ok for street if you like to play around with low wheelies and other stuff. Pretty usefull..
JT
JakeT is offline
post #13 of 23 Old 06-07-2005, 10:28 AM
Kuss929's Avatar
I would go along these lines first before I put up the scafolding.
http://www.nrcracing.com/covers.php
A stronger cover might have prevented all that damage. Depends on what hit first.
There are some who call me ............................Tim
Kuss929 is offline
post #14 of 23 Old 06-07-2005, 11:24 AM
That's nice , But according to there site they only make it for an 02 600fi. No good for my 954
Go Bruins, Game on eh Next Year AGAIN. JJ BITES!!!
KJ's RR is offline
post #15 of 23 Old 06-07-2005, 11:59 AM
Kuss929's Avatar
I thought that they made them for the big CBR's also but maybe they don't.
Kuss929 is offline
Oil leaking from left case, Please Help???? Hondalush318 Honda FireBlade 12 06-17-2004 2:33 AM
Just installed my Billet Tech case cover yeelepm3 Honda FireBlade 8 05-24-2004 10:35 AM
Billet Tech case covers for 929 & 954 wertman94 Honda FireBlade 1 04-07-2004 7:30 PM
I made something ! Wohoo! MarkN929RR Honda FireBlade 8 11-01-2003 5:40 PM
