929, 954 front brake master cylinder piston size. - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 07-09-2003, 8:34 AM Thread Starter
Re: 929, 954 front brake master cylinder piston size.
Does anyone know what diameters they are?
CraigB is offline
post #2 of 10 Old 07-09-2003, 9:40 AM
5/8' I believe.
abtech is offline
post #3 of 10 Old 07-10-2003, 12:04 AM
First Post, Learned this while researching a master cylinder for my buddy's R1 race bike (for less money than a brembo radial&#33. 929 has a 19mm bore, and 954 has 17mm bore. 929 caliper pistons are 36mm and 30mm, 954 are 34mm and 30mm. I don't remember if caliper measurements are correct but 954 is 2 mm smaller on the upper piston. I work at a honda- yamaha dealership so I have access to trivial things such as this! by the way a 02 R1 master cylinder is 14mm!!!
rrfiddyf5 is offline
post #4 of 10 Old 07-10-2003, 7:35 AM Thread Starter
Thanks rrfiddyf5 and abtech.
Very helpful info.
Unfortunately stupid me bought a 954 master off ebay thinking it was the same size as a 929. Since it was from a dismantler I asked if they could send a 929 one instead if they had it. Otherwise I will try and do a trade, swap with a local wrecker.
Thought the lever travel was a bit too much with the GSXR master with its 5/8 piston size.
Thanks again.
CraigB is offline
post #5 of 10 Old 07-10-2003, 10:25 AM
Any reason the 929 has the larger master cyl?
Sirkbac is offline
post #6 of 10 Old 07-27-2003, 10:41 AM
19mm? Can that be right? Can someone with a manual confirm that? It seems odd to me that Honda would go from a 5/8' - 15.9mm (CBR900) to a 19mm, and then back to a 17mm on the 954. Although the 17mm seems more plausible.
I'm thinking of fitting a CBR master to my VFR800 (currently 1/2' - 12.7mm), and am having a beast of a time finding what sizes they are.
Thanks for any help!!
ManaBurrn is offline
post #7 of 10 Old 07-28-2003, 9:34 AM Thread Starter
ManaBurrn, I measured the 954 piston and it is 17.35 mm.
The 929 looks bigger from the outside but that is only a guestimate.
rrfiddyf5, or any one else can confirm the caliper piston sizes. It looks as though I bought 954 calipers off Ebay but I think they were sold to me as 929. The pistons are close enough to 34 and 30 mm. Maybe the 954 might be 32 & 30?
CraigB is offline
post #8 of 10 Old 07-28-2003, 11:39 AM
I just checked Ron Ayers and they have different part numbers for the calipers (seals, pistons, etc) but they are on the same microfiche page. I don't know about the caliper piston size differences but I will try to measure mine (1 929 caliper, 1 954 caliper) over the next week or so (I need to pull the wheels off the bike anyway).
FYI, I didn't order enough seals when I rebuilt my calipers so I could only do 1 of them. I had to do some side work for a salvage yard and picked up a 954 caliper for the 929 so I would have a complete set of good calipers that didn't stick. It bolts right on and I had good braking power during my races. If they are different sizes then I don't know that you will notice much, however, if you can wait though this week then I will attempt to measure both the 954 and the 929 caliper pistons for comparison.
lfg929 is offline
post #9 of 10 Old 07-29-2003, 8:49 AM Thread Starter
Thanks lfg929.
My local Honda dealer didn't have the seals in stock so no luck. I have not called the Honda distributor directly as I thought it may be easier for me to find the answer here.
Thanks again, Craig.
CraigB is offline
post #10 of 10 Old 11-28-2006, 8:22 PM
so basicly smaller = better ?????
if thats the case i can just swap my 929 ones into 954 i hope its the same fit
emazens is offline
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 8:27 PM
what size master cylinder on a 929? jaxon23 Honda FireBlade 7 10-24-2003 3:59 AM
