Bar end Question - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 07-05-2004, 5:34 PM Thread Starter
Hammer's Avatar
Reputation Power: 33
Bar end Question
I am wanting to change the barends on the 54 to a LP carbon inlay type and the LP ends come with rubber or without. Does the 954 have rubber or not?
It's amazing how stupid some people can be.
Hammer is offline
post #2 of 10 Old 07-05-2004, 6:35 PM
davef's Avatar
Reputation Power: 17
Re: Bar end Question
Mine didn't have any rubber on it, just a screw and a black metal bar end
Make sure you use locktite when you put the new bar ends on, or else the screw/allen head will fall off!
2002 954 Full Ohlins, Galfer Wave Front Rotors, Scotts Damper, MIG High Mount, 16/45 520 Conversion...Sweeeeet
1996 CBR600F3 Smokin Joe's Edition
Gets good MPG...
davef is offline
post #3 of 10 Old 07-05-2004, 10:34 PM
Do the LP's fit the 954?
01 CBR 929
08 Ducati 1098
Florida Trackdays
GiveGab
fl-929 is offline
post #4 of 10 Old 07-05-2004, 11:44 PM Thread Starter
Hammer's Avatar
I hope the LP ones fit .. I just do not know if the 954 takes the rubber piece or not. I have the matching frame sliders and would like the bar ends to match.
Hammer is offline
post #5 of 10 Old 07-05-2004, 11:45 PM
I just purchased lp bar ends, and the bolt that comes on them doesn't fit my 01 929 at all. Hopefully you'll have more luck with the 954...
Has anyone put these lp bar ends on their 929? If so, which model...I was hoping to go with the gold.
mb
mbuckley is offline
post #6 of 10 Old 07-05-2004, 11:45 PM
Not unless you remove the inner bar weight. Then the ones with rubber MAY fit. But, it's all a bad idea anyway since you want as much weight there as possible to help cut down on the vibrations. The LP ends are lighter than the stock ones, and if you have to remove the inner weights to use them, you'll be hating life.
ConqSoft is offline
post #7 of 10 Old 07-06-2004, 12:00 AM
Unless your name is Stegen...
Bacchus is offline
post #8 of 10 Old 07-06-2004, 12:54 AM
My bar ends are stock and my hands ALWAYS go numb after an hour or so!!!!
Brian929RR is offline
post #9 of 10 Old 07-06-2004, 3:55 AM
davef's Avatar
Mine are the extra heavy brushed metal ones and they make a huge difference. I can't remember the brand. I bought them new for the 929 and they've been on the RC and now the 954. They help so much, the mirrors are even clearer because of less vibes.
ps. Lockhart stuff is usually kinda junky...
Gets good MPG...
davef is offline
post #10 of 10 Old 07-06-2004, 10:51 AM
I made some heavy SS bar ends. They work well. If you take the stock weights out and put in the LPs, try not to ruin any of the stock stuff - you'll probably want to put it back in there after a ride or two.
Joel is offline
Bar Ends for CBR 929 Ivo Honda FireBlade 7 06-05-2004 1:39 PM
Front end alignment Question disbjohn Honda FireBlade 2 05-04-2004 10:57 PM
removal of bar end weights? silver954 Honda FireBlade 4 05-24-2003 8:38 PM
