Hindle Bolt on question - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 07-10-2004, 7:56 PM Thread Starter
Haven't finished the GPR Damper install yet working on Hindle exhaust
can. I will post pics and descriptions when I am done with all the addons.
The replacement GPR base came in and I have that mounted and torqued
down. After I get the can installed I will finish the damper.
Anyway, I got a Hindle oval carbon fiber bolton exhaust can. It came with no
instructions and nothing but the bolts and clamp to mount it. I am wondering if I should used the stock exhaust gasket? Or get and some gasket material and use that? The stock gasket is about an 8th of an inch think and doesn't let the exhaust can mount flush to the stock pipe mounts. Anyone out there install the Hindle oval can on a 03 954? And if so can you tell me what you did for the gasket?
TIA
jaim is offline
post #2 of 3 Old 07-11-2004, 8:45 PM
Re: Hindle Bolt on question
My gasket would not come off, I just tightened the can against it and it worked just fine. The little gap was unoticed to anyone but me. If fits really tight over the cone on the end of the pipe. I would recommend removing that as well.
Smitty929RR is offline
post #3 of 3 Old 07-12-2004, 6:25 AM Thread Starter
Removed the Honda stock gasket and used the High Temp Copper RTV sealant. Haven't started the bike yet. Letting the sealant cure overnight. I am worried I didn't make a large enough bead though. If not, I will take it apart, clean it and start over. Funny thing about the cone. I don't have one. I live in California and the catalytic converter appears to be in the stock can. A large honeycomb mass is in the base of the stock can. So I would imagine a stock exhaust can would be pretty price. Also, the stock can has a "nice" bend internally. It definitely is not straight though. Just getting rid of that can should give me a nice like pick me up when I turn the throttle.
jaim is offline
FI light question after Hindle install Fossil Honda FireBlade 13 10-17-2005 5:37 PM
Fork Pinch Bolt Problem BushrodW General Discussion 12 05-28-2004 4:50 PM
Hindle bolt on Gadget369 Honda FireBlade 11 08-18-2003 12:10 AM
Hindle install question aussie_929 Honda FireBlade 14 05-24-2003 11:47 PM
