954 enine in a 929 frame - Honda Motorcycles - FireBlades.org
post #1 of 27 Old 07-11-2004, 8:10 PM Thread Starter
Can it be done? My friend just picked up a high mileage 929 and has a extra 954 engine. Any one done this yet?
Paul
Paul is offline
post #2 of 27 Old 07-11-2004, 8:18 PM
Re: 954 enine in a 929 frame
I think the mounting points on different on the 954. With that said, anything can be modified to fit, bracket and braces.
Mojave954 is offline
post #3 of 27 Old 07-11-2004, 8:27 PM
It's done quite easily, I did it a while back. Engine bolts right up, swingarm bolts right on. You'll have to modify the wiring harness for the bank angle sensor, it's located under the seat on the 929 but it's behind the headlights on the 954. The gauges are not interchangeable. If you're using the bigger 954 throttle bodies, they don't seat perfectly into the 929 airbox and the 954 airbox won't fit under the 929 fuel tank. Everthing else was plug and play if I remember correctly. Good luck!!
Cowboy is offline
post #4 of 27 Old 07-12-2004, 5:40 PM Thread Starter
thanks cowboy, It'll be a fun project that's for sure
Paul is offline
post #5 of 27 Old 07-12-2004, 5:51 PM
Tornado bait's Avatar
Reputation Power: 26
If you don't want to deal with the bank angle sensor you can bin it and jumper the harness. Although I know some people are scared to death to operate without it, I took it off my 929 (street) and F4i (track) with no problems. I even crash tested my track bike twice with no drama what so ever.
Tornado bait is offline
post #6 of 27 Old 07-13-2004, 2:25 PM
I'm about to do the same swap in the coming months.
victoRR is offline
post #7 of 27 Old 07-13-2004, 2:46 PM
Just outta curiosity how does someone have an extra engine just laying around
929_Nupe is offline
post #8 of 27 Old 07-13-2004, 3:39 PM
www.ebay.com
victoRR is offline
post #9 of 27 Old 08-06-2004, 11:47 AM
I did the reverse to what you're doing, i gat a 01 929 engine in a 954 frame...everything lined straight up, except I had to change the subframe and rear cowl section, the airbox had to be changed along with the tank being changed to 954.... the bank angle sensor was the only problem, I monted it using tie straps to the part that is attached to fairing clip on the left hand side, and haven't had any problems with it yet.... however I don't do any wheelies or stoppies yet though!
honourebel is offline
post #10 of 27 Old 08-08-2004, 9:11 PM
I have a 929 with a 954 motor in it, and it has all the other stock 929 parts, guages, etc. Swap wasn't hard at all, its the same motor just punched out a bit
MotoDave is offline
post #11 of 27 Old 08-09-2004, 5:36 AM
stopsign's Avatar
Reputation Power: 19
Send a message via AIM to stopsign Send a message via Yahoo to stopsign
I don't kill flies but I like to mess with their minds. I hold them above globes. They freak out and yell, 'Whoa, I'm way too high!'
stopsign is offline
post #12 of 27 Old 08-09-2004, 1:42 PM
Err, what does the bank angle sensor do?
(Sorry for the hijack)
Forget it. I just found out!
DavidW is offline
post #13 of 27 Old 09-26-2004, 3:22 PM
Ok, so if I have a 929 bare motor and swingarm, could I use all the rest of the 954 stuff and bolt the engine and swingarm right up?
jcrojas is offline
post #14 of 27 Old 03-14-2005, 6:06 PM
Send a message via Yahoo to CBR629
[QUOTE=Cowboy]It's done quite easily, I did it a while back. Engine bolts right up, swingarm bolts right on. You'll have to modify the wiring harness for the bank angle sensor, it's located under the seat on the 929 but it's behind the headlights on the 954. The gauges are not interchangeable. If you're using the bigger 954 throttle bodies, they don't seat perfectly into the 929 airbox and the 954 airbox won't fit under the 929 fuel tank. Everthing else was plug and play if I remember correctly. Good luck!! [/QUOTEdid you have to change the powercommander?
IF YOU CAN'T KEEP UP,DON'T STEP UP.
CBR629 is offline
post #15 of 27 Old 03-14-2005, 6:56 PM
No, you won't have to change the PC. You're not changing the ECU.
someoneandhis929 is offline
100,000 kms on a 929 omen137 Honda FireBlade 20 10-08-2004 1:21 PM
A 954 frame on a 929? Paul Honda FireBlade 3 03-15-2004 1:59 PM
will 954 frame sliders fit 929? tnarinen Honda FireBlade 1 02-16-2004 12:04 PM
929 forks fit on a 954??? synrrgy Honda FireBlade 4 12-01-2003 8:27 PM
