Suspension settings, 929 - Honda Motorcycles - FireBlades.org
post #1 of 6 Old 07-20-2004, 7:28 PM Thread Starter
All,
Now that I am used to the bike, (and the new 180 rear tire), I would be interested in finding out what the best known set up for this bike would be in regards to the suspension. I really enjoy the bike now and understand suspension may be set to your liking and riding style. If there is a commonly known set up that works well with this set, please let me know. If this helps, I am 5-7,185 if that matters. If anything I can find out if I like it better than the current set up.
Thanks
Ez
ezracer is offline
post #2 of 6 Old 07-20-2004, 8:26 PM
EatnAsphalt's Avatar
Reputation Power: 19
Re: Suspension settings, 929
Take a look at the bottom of the thread for some other similar threads. Basically the stock fork springs are too soft, you need .90-.95 springs for your weight and the valving revalved for your weight.
Someone around here might have some suggestions on what to set the stock stuff at but if you really want it to work well you'll have to spend some $. Dan Kyle does great work on the forks. Made a night/day difference on my bike.
EatnAsphalt is offline
post #3 of 6 Old 07-20-2004, 11:25 PM
Here's what I orignally set my bike up to (I got it off some performance site long long long ago; it was a night/day difference from stock)
Rear
Preload position, 7 of 9
Rebound, 3/4 turn out from full in
Compression, screwed in full clockwise
Front
Preload, 2 lines showing [4mm showing,measure from bottom
of preload nut to topof fork cap]
Rebound, 1/2 out from full in
Compression, 3/4 turn out from full in
Lately; I've been thinking the front is a little soft; and I know I've increased the pre-load on the rear since this... but here's a good start...
I'm running a 180 as well; i don't think I'll ever go back to a 190.
-Rob.
SpikedLemon is offline
post #4 of 6 Old 07-21-2004, 12:49 AM Thread Starter
Thanks guys, just what I was looking for.
ezracer is offline
post #5 of 6 Old 07-21-2004, 3:29 AM
EatnAsphalt is right on. The stock ssupenders were to soft out of the crate for the bikes weight. Forget putting a rider on it. Static sag can not be set properly do to this which means "game over". An important point is to remember the suspension must be viewed as a system. If you fix the front end you must address the problems with the rear as well. Forks and shock must work together. Therfore, consider getting a completly new setup from a reputable source who has experience with you bike and the products you select i.e. Fox, Ohlins. White etc. Finally, any stock suspension is junk after 10k miles. If you've got that or more in her now, make the change. You won't believe the difference.
Once you're done look into articles on setting sag (static and dynamic) as well as rebound and compression settings. This will give you many enjoyable (?) hours of tinkering to get it "right". But is is well worth the effort. The 929 is a phenominal mortorcycle and you've only scratched its performance surface.
_________________________________
Maintain speed regardless of conditions
paularthur is offline
post #6 of 6 Old 07-21-2004, 9:04 AM
I would suggest reading sportrider for me this gave me a good starting point.
Once you understand rebound damping, preload, and comp. damping front and rear. Then you can start tinkering with settings to fit the way that you ride or the roads you ride..
These are the settings i run right now..
settings.gif‎
CBR929Junkster is offline
suspension settings CBR929RE General Discussion 2 07-10-2004 4:55 PM
Harsh ride and suspension settings TireSmoke Honda FireBlade 2 05-28-2004 7:38 PM
929 Suspension Help franklaw996 Honda FireBlade 10 05-20-2004 9:55 AM
Optimum track suspension setup for a 929? Ivo Honda FireBlade 3 04-06-2004 9:03 PM
Suspension Settings jensen Honda FireBlade 4 08-10-2003 4:34 AM
