CBR929rr Running on 2 cylinders - Honda Motorcycles - FireBlades.org
post #1 of 17 Old 07-25-2004, 4:00 PM Thread Starter
As the title states my 01 929 is only running on the 2 & 3 cylinders. Its not the coils as they have been swapped around and still 1 and 4 are just not firing (as detected from spraying water on the headers). What else could I check other than the ECU?? Bike only has 2500 miles 1700 of those from me.
I have been looking at this site for a while and I'm glad to have finally joined. Thanks to anyone with some help, Wes Brown
Erion-929rr is offline
post #2 of 17 Old 07-25-2004, 4:03 PM
Re: CBR929rr Running on 2 cylinders
Injectors, plugs, ECU.
Do you have a Power Commander? If so, remove it and try again.
BDA116 is offline
post #3 of 17 Old 07-25-2004, 4:16 PM Thread Starter
No power commander. Forgot to mention that I replaced the plugs. I think fuel injectors are out because the plugs are very wet when removed. I guess I just dont want to think that its the ECU $$$$$$. Any more suggestions??? Thanks, Wes
post #4 of 17 Old 07-25-2004, 7:34 PM
Swap around or put in new plugs. I spent about $300 *fixing* (thowing parts) a bike after I put in new plugs. One of them was simply non-functional right out of the box! (Damn Honda branded NoGoodKind plugs). Meachanic put in a new plug and viola.. fixed (leaving me with parts like new plugs wires and coils that I really did not need). Try it, it's not that time consuming and should not cost much to try.
You have to run your troublshooting tree and the first question you need to ask is "What changed?". Good luck. With Honda with so few miles I would be shocked it was anything more than plugs (bad gap or just plain bad).
Holeshot is offline
post #5 of 17 Old 07-25-2004, 7:58 PM
i have an ecu if you need one. let me know.
Superbike Supply is offline
post #6 of 17 Old 07-25-2004, 11:01 PM Thread Starter
Well it seems like it has to be the ECU. Ebay is my friend tonight with a guaranteed working model for 75 shipped.
I know what you mean about the troubleshooting tree Holeshot, my previous ride was an F2 that liked to smoke up rectifiers. Honda electrics and my family have never gotten along. Dad and brothers VFRs both have had new rectifiers as well. Maybe our house is on an old Native American burial ground????
I'll let you know what I come up with. If anyone has anything else to add please give it a go as I will be waiting for my part for a few days at least, Wes Brown
post #7 of 17 Old 07-29-2004, 5:10 PM Thread Starter
No joy with the new ecu. Correct me if I'm wrong but the ecu goes directly to the coils, no silly sensors or anything between them right? I have all the luck. Wes
post #8 of 17 Old 07-29-2004, 5:12 PM
stegen's Avatar
Reputation Power: 23
what do you mean the injectors are out? like not working?
stegen is offline
post #9 of 17 Old 07-29-2004, 5:25 PM
You are right and wrong. The negative side of each injector comes from the ECU "A" or Black Connector side. The Hot side of the injectors are connected to battery pos through the Engine Stop relay and fuse F1.
Note: The hot side of the injectors are shared and color coded as BLK/WHT.
aBnorMal is offline
post #10 of 17 Old 07-29-2004, 7:29 PM Thread Starter
Ok, after I got done beating my head against the wall I stopped and thought about things. What I have discovered is that the Plugs are firing(at least on the block) and I am getting fuel. Could I be getting so much fuel that the plugs can't cope and only burn partial in turn cooling those cylinders so much that it seems like no fire? Also is there anything (sensors, wiring wraps) on the bike that would be divided up cylinders 1&4/2&3?
Got out the multimeter and started poking around with sensors I know nothing about. I have a Haynes book and was checking the throttle position sensor wires and discovered that one of the power wires has 4.99v and the other has like .5v. In the book it says they should be the same, however the book also says the wrong color wires.....hhmmmmmmmm.
I hate this kind of crap, couldn't have been the plugs.....nooooooooooo, that would have been to easy for me. Dammit. thanks for listening and for the help , Wes Brown
post #11 of 17 Old 07-29-2004, 7:53 PM
dB
Or maybe those plugs aren't firing at the right time? I think it would be hard to do, but any chance you swapped those two plug wires?
dB is offline
post #12 of 17 Old 07-29-2004, 8:05 PM Thread Starter
I thought of that but the wires are only long enough to go to the proper coil. Wes
post #13 of 17 Old 07-30-2004, 9:01 AM
If your meter reads resistance than read across each injector. Should read 11 ohms (give or take an ohm or two) if it reads open or anything out of the given tolerance then it's bad. I've had two bad injectors on two different occasions. Both were reading open. One was stuck in wide open spray and the cylinder and plug were so wet it wouldn't fire.
aBnorMal is offline
post #14 of 17 Old 07-30-2004, 10:17 AM Thread Starter
Good suggestion, I will try that out this afternoon after work. Wes
post #15 of 17 Old 07-30-2004, 4:43 PM Thread Starter
Well the injectors checked out ok on the meter. I guess it could be a possibility of them sticking on , but how do I check that???
I would just take it to the dealer , but what I heard on the phone from the service guys about my carbs (929 mind you) I feel as though I could track down a problem as fast, if not faster than those yaa-hoos. Wes
Keep That Old Motor Running Moto Off-Topic 0 04-07-2004 3:00 PM
Well, the 954 is back up and running! K9inAZ Honda FireBlade 4 12-24-2003 12:41 PM
