Useless Mirrors on a 929 - Honda Motorcycles - FireBlades.org
post #1 of 22 Old 08-10-2004, 10:13 PM Thread Starter
Just wondering if I am the only one that finds that my mirrors on my '00 929 vibrate an unbeliveable amount at anything over 4000rpm. I can still see cars but they are just a big blur of colour, no way I could make out the person driving. My screen tends to move about as well (maybe about 3mm-5mm play).
Is this normal? I have tried to tighten up all the bolts in the area but can't seem to take out the play.
Thoughts?
Denied
'00 CBR929RR Red white and Blue
Perth, Australia
Denied is offline
post #2 of 22 Old 08-10-2004, 10:15 PM
Baketech's Avatar
Reputation Power: 42
Re: Useless Mirrors on a 929
Are all 4 plug wires connected....
Sith Apprentice
CBR929 - VFR800 - VFR800
Baketech is offline
post #3 of 22 Old 08-10-2004, 10:20 PM
Normal on mine.
G-Force Junkie is offline
post #4 of 22 Old 08-10-2004, 10:21 PM
Thoughts?
Denied
Perth, Australia
get the bike up to about 6 or 7k and above and see if they get clear again ... the 929/954 engines resonate around 4-6000 rpm's and make the bike buzzy ...
if you will notice at or about the same time the mirrors go fuzzy the grips will get buzzy also and vibrate
FullForce is offline
post #5 of 22 Old 08-10-2004, 10:25 PM
CBR929RE's Avatar
Reputation Power: 39
I get some vibration in my mirrors on my 01 but it seems to me that its just the normal lack of FI smoothness that a PC3 takes care of and the road conditions around here. but I wouldn't say its all that bad so you gotta have some issues. that windscreen thing is weird, not missing any nuts are ya?
CBR929RE is offline
post #6 of 22 Old 08-10-2004, 10:33 PM
The only "buzziness" my mirrors experience is at idle (1,200 rpm).
Bacchus is offline
post #7 of 22 Old 08-10-2004, 10:34 PM
Ever do a throttlebody sync? Might be worth your while
2OHOH2 is offline
post #8 of 22 Old 08-10-2004, 10:41 PM
EatnAsphalt's Avatar
Reputation Power: 19
Mirror extenders seem to make them vibrate less. I don't have much trouble with mine on my 929 or maybe I've just gotten use to it.
I got the mirror extenders from one of the members here. http://www.rrmotorsport.com
EatnAsphalt is offline
post #9 of 22 Old 08-11-2004, 1:10 AM Thread Starter
The vibes on my bike are probably the worst at around 6500. Pegs vibrate and the vision in the mirrors is soooo purdy in all it's swirly vibrating goodness. My girlfriend always complains if I leave i leave it revving around 6500-7500 cos her pegs vibrate enough to make her feet numb.
As for the missing nuts, I had the screen out when I bought it so that I could detail all the instruments and everything seemed intact and accounted for.
Throttle body sync? My bike is about to go in for it's 12k service... you reckon this will be included in that??
Denied
00' CBR929RR Red Blue and white
Perth, Australia
Denied is offline
post #10 of 22 Old 08-11-2004, 1:21 AM
Probably not, as it's not part of the regular maintenance that Honda calls for. It should be about a 30 minute procedure, for a noob, and 10 minutes if you know what you (or the mechanic) are doing. When I asked my local Honda mechanics about it, they had no idea what I was talking about You should request it, or better yet, do it yourself.
Basically, you use a carb sync tool to sync/equalize the vacuum that your TB's are pulling.
Here's one such tool, with a how-to: http://www.carbtune.com/carboprn.html
2OHOH2 is offline
post #11 of 22 Old 08-11-2004, 1:29 AM
Dude, have you checked out all bolts on the bike, especially enging mounting bolts? You probably have, but this problem sounds like it should not exist.
Now if you could just funnel that vibration up to the pillion, you would have one happy SO!
Bacchus is offline
post #12 of 22 Old 08-11-2004, 2:06 AM Thread Starter
I haven't checked all the bolts on the bike, but now that you mention it I think i might put the bike up on the stands and pull all the body work off and have a good look at what's going on under there.
I think I will have a look into the carb balancing too... I have had absolutely NO luck with services over here in the land of Aus. It seems that it's much better to do stuff yourself if it's possible because when it comes down to it... you care about your motorcycle... a shop doesn't... cos it ain't theirs... is it?
Denied
'00 CBR929RR Red White & Blue
Perth, Australia
Denied is offline
post #13 of 22 Old 08-11-2004, 7:57 AM
Denied
Perth, Australia
I had a 929 for almost 3 years - mirrors were always great except for 2 times. One was where I hadnt tightened the damn thing back up properly after a track day. I thought it was vibrating abrormally right before one of the mounting screws popped right out...The second issue involved me leaving one behind after highsiding at Sanddown. Cant really blame the mirror for that one (left a nasty bruise on my chest too...).
warthog is offline
post #14 of 22 Old 08-12-2004, 7:10 PM
Reputation Power: 17
You may be running aftermarket mirrors on it and not know it if you bought the bike used. Mirrors are the first thing to break if you go down and they could have been replaced with aftermarket usually "Emgo" mirrors. Check the bottom of the mirror and see if they say Emgo on them. They are an ok product in my opinion, (there an my bike). But some folks have problems with them vibrating alot more over the stock ones.
"and when I gun the engine I want it to sound like the world is coming to an end" -Homer Simpson
ucfmotorcycle1 is offline
post #15 of 22 Old 08-12-2004, 7:20 PM
stegen's Avatar
Reputation Power: 23
pffst! 4k? try 11k.
stegen is offline
100,000 kms on a 929 omen137 Honda FireBlade 20 10-08-2004 1:21 PM
929 almost stolen Grunt Honda FireBlade 14 07-09-2004 12:51 AM
929 Replacement Mirrors rrbarna Honda FireBlade 2 11-15-2003 9:22 PM
