954 camshaft removal - Honda Motorcycles - FireBlades.org
post #1 of 31 Old 08-29-2004, 5:04 PM Thread Starter
Recently, I posted a question about unloading the cam chain tensioner on a 954. I had the official Honda tool (07ZMG-MCAA400) intended for that purpose, but lacked success in getting it to turn. The local dealer had the same result, although the mechanic did say that he never uses the official tool. Instead, he prefers a long thin screwdriver.
Unless a screwdriver is particularly flexible, I donít see any way to get it into the tensioner body.
Removal of the tensioner is not without its own problems, because the upper 8mm bolt is pretty much inaccessible.
With the 954 on a rear track stand, I removed the muffler, loosened the rear hanger bolt, removed the four forward hanger bolts, and lowered the motor about two inches using a jack under the oil
pan. The tensioner was then easily accessible. By unbolting the radiator, the cylinder head cover could be removed from the front; much easier than up through the frame. I also think the additional two inches of clearance helped when I removed the cams.
cylinder head 02.jpg‎   profile 02.jpg‎
OldBob is offline
post #2 of 31 Old 08-29-2004, 6:15 PM
Reputation Power: 17
Re: 954 camshaft removal
I just went through this. Make the little tool that is in the 929 manual (it's posted here somewhere, do a search). It worked great for me. No need to remove or lower the engine, just unhook the harness cables near the CCT and access is no problem. I needed to loosen the radiator to get the valve cover off, but that is all. The rest is fairly straight forward.
ULEWZ is offline
post #3 of 31 Old 08-27-2010, 4:18 PM
This thread is old but I'm having the same issue. Anybody have any more advice? R anyone have the tool I need? I'll buy it
repsolracer22 is offline
post #4 of 31 Old 08-27-2010, 11:07 PM
Reputation Power: 12
Old thread alright!.You can make your own cam tensioner release tool from 1mm steel.The top tensioner bolt is tight to get to, but it is possible to undo with a 1/4" universal joint, replace it with a cap head bolt which is much easier to remove in the future.That guy really wasted a lot of time removing the radiator, dropping the engine etc.
mondo is offline
post #5 of 31 Old 08-28-2010, 1:12 AM
Reputation Power: 26
Meh, I ended up doing the same thing as the OP. I replaced my cam tensioner with a manual one.
I spent more time trying to make a universal joint/swivel sockets work than it took me to lower the engine.
Deadsmiley is offline
post #6 of 31 Old 09-02-2010, 3:34 PM
i already made the tool. the tensioner is not even in the motor right now. and my cam chain is too tight and wont go on the cam gears ..... help
post #7 of 31 Old 09-02-2010, 4:00 PM
The cam chain will go on the gears if you remove the cam chain tensioner (item #4).
What is commonly called the cam chain tensioner is the tensioner lifter (item #3).
Be sure to use locktite on the bolt (item #10) when you reinstall it.
Oh, and watch out for that washer behind the tensioner. It could easily get lost in the pan if you aren't careful...
954_CCT.jpg‎
2002 CBR954RR, 1998 VFR800
post #8 of 31 Old 09-02-2010, 4:03 PM
Reputation Power: 11
i already made the tool. the tensioner is not even in the motor right now. and my cam chain is too tight and wont go on the cam gears ..... helpi already made the tool. the tensioner is not even in the motor right now. and my cam chain is too tight and wont go on the cam gears ..... help
You'll have to take the sprockets off the camshafts, put them 'in' the camchain then put the sprockets on back on the camshafts.
Good luck
shittyarsedmonk is offline
post #9 of 31 Old 09-02-2010, 4:05 PM
Good luck
No you don't. I removed and installed my cams without removing the sprockets (see above).
post #10 of 31 Old 09-02-2010, 4:11 PM
well ......
as of right now, the cam chain tensioner is not even in the motor at all ... so theres nothing pushing against the cam chain to make it tighter ..... its freely moving and touching nothing.
i put the 2 cam shafts back on just like i took them out. i can get the chain around them but the OTHER side of the cam shafts does not sit down flush. they are raised slightly because the chain slack is too tight. but its in time perfectly. if i take it out of time, then it creates more slack .... but when its in time its too tight to where i cannot even put the cam holders back on ... and then if the tensioner is on, then we would have a problem cause theres nothing to tension. its too tight. wtf
post #11 of 31 Old 09-02-2010, 4:19 PM
well ......
Crap, got item 3 and 4 swapped!
Take out ITEM 3 and you will have more slack in the chain than you know what to do with.
Go ahead and install the cams with sprockets back on the head. Leave Cam Chain Guide "B" (Item 6) off the head. This will make it easier to deal with.
Sorry for my blunder mate.
954_CCT.jpg‎
post #12 of 31 Old 09-02-2010, 4:21 PM
explain that again .........
post #13 of 31 Old 09-02-2010, 4:26 PM
But did you remove the chain guides? See what above?
post #14 of 31 Old 09-02-2010, 4:29 PM
this isnt making sense. why would i have to remove the cam chain tensioner inside the motor? it just sits in there loose when the tensioner lifter isnt bolted to the motor.
post #15 of 31 Old 09-02-2010, 4:33 PM
1) Take out the bolt (Item 10) and remove the cam chain guide (Item 3). This will give you plenty of chain slack.
2) Install the cams with sprockets attached.
3) Install the cam chain.
4) Install the cam chain guide (item 3) and check your timing. If all is well, install cam chain guide "B".
Can you see the picture I attached? It gets a lot bigger when you click on the thumbnail.
You don't need to remove the sprockets from the cams.
You do need to leave off Cam Chain Guide "B" until you get everything timed.
954 vs. New '04 R1 Mako Honda FireBlade 18 07-16-2005 2:11 PM
'03 954 swingarm removal New954RRider Honda FireBlade 3 06-12-2004 12:58 AM
CBR1000RR vs 954 dilema StuUK Honda FireBlade 4 04-20-2004 8:42 AM
