15 t sprocket? - Honda Motorcycles - FireBlades.org
post #1 of 10 Old 09-12-2004, 11:36 AM Thread Starter
15 t sprocket?
I installed a 530RK chain with 15/43 AFAM sprockets.
Could I have installed one less link in my chain to shorten the weelbase, the chain ajuster is half way with everything new?
I did a top end run and my bike toped off at 177mph hitting rev limitter. I have no speddo ajuster so spedo is off, but is the 15t a little to much on the power side, If my goal is max power/speed, shoul I try another setup such as 16/45?
No civils where put at risk during this test. Did not do it on the streets.
Thanks.
btw I am correct by saying that the actual top speed was 177mph -12%=156mph ?
Isn't the top speed supposed to be around 176mph? I have already seen 173mph with stock sprocket.
All info gattered here is for track purpuse only.
l'timbré is offline
post #2 of 10 Old 09-12-2004, 12:08 PM
Re: 15 t sprocket?
I was told dropping one in the front was about the same as adding 2 (2.5) in the rear.... power wise but it was supposed to give you more top end
I also though bigger rears = more torque and a lower top end speed
Some one just in and correct me if i'm wrong
929_Nupe is offline
post #3 of 10 Old 09-12-2004, 12:09 PM
Sponsor
SilverBullet's Avatar
Reputation Power: 21
Re: 15 t sprocket?
With the 15t, your max speed will decrease a hair. If you go up in the back, it will decrease some more. Your 15t front just gives you a little more pull, and theres no need to shorten the chain. The axle is fine where it is.
SilverBullet is offline
post #4 of 10 Old 09-12-2004, 12:28 PM Thread Starter
Re: 15 t sprocket?
I thaught -1 front = +3 rear so if this is right, keeping the 16 front and adding 2 to the rear, would not be as ''radical'' as -1 front.
The axle is fine in the center but I prefer the shorter weelbase for faster turns. Would -1 link fit with 15/43?
l'timbré is offline
post #5 of 10 Old 09-12-2004, 1:00 PM
Sponsor
Re: 15 t sprocket?
Either way, its a difference that you will notice, atleast I did, and many others on here have said the same thing. I think -1 front is more like +2 rear, but many people do both.....I only went up 1 in the rear, so -1 front +1 rear because in the 1/4, I'll probably top out if spraying....I think Sonicbomb does top out in the 1/4.
post #6 of 10 Old 09-12-2004, 4:27 PM
CBR929RE's Avatar
Reputation Power: 39
Re: 15 t sprocket?
I've been told -1 in front is like +3 in rear maybe even a little more (not quite 4 but between them)
CBR929RE is offline
post #7 of 10 Old 09-12-2004, 9:50 PM
Off topic but
l'timbre.... youre french canadian right ????
jfboy is offline
post #8 of 10 Old 09-13-2004, 6:46 AM
Re: 15 t sprocket?
Yes I top out in the 1/4 with -1/+2 (15/45) top speed on my bike is only 156mph but I do it in 1/4 mile
sonicsbomb is offline
post #9 of 10 Old 09-13-2004, 7:46 AM Thread Starter
Re: 15 t sprocket?
do you have a yellow box if not what is your speedo reading? I presume the 156 mph is the readings from the strip.
l'timbré is offline
post #10 of 10 Old 09-13-2004, 8:45 AM
Re: 15 t sprocket?
no box, but I think actual speedo reads like 165 or so not real sure don`t pay to much attention to it but I think my speedo is like 10 mph off
Not your usual sprocket question, I need your input HyrePower Honda FireBlade 12 06-21-2004 1:41 AM
One more Sprocket question? Hellfire666 Honda FireBlade 1 04-30-2004 12:06 AM
