Ohlin fork springs. On 03 954 - Honda Motorcycles - FireBlades.org
post #1 of 15 Old 09-15-2004, 2:10 PM Thread Starter
Ok after doing alot of reading, I am thinking on replacing my stock fork springs with ohlins. From what I can tell the lengh should be the same and I wont need to cut a new spacer. I am also thining on revalving with either Ohlins or Racetek gold valves. Any insight would be great. I am 5'11" and 193lbs.
RayGun is offline
post #2 of 15 Old 09-15-2004, 2:21 PM
sporky's Avatar
Re: Ohlin fork springs. On 03 954
go for it. 98kgr here (must be around 210 pounds) I placed the 0,90 Ohlins and handling + braking changed substantially. No dramas any more, you can use the full potential of the bike.
S...
dream you will live forever, live like you will die today
sporky is offline
post #3 of 15 Old 09-15-2004, 2:32 PM
At your weight (I assume that is net weight and doesn't include your riding gear), I would go for 1.0 KG springs if you run at the track or .95 KG springs if you run primarily street.
Don't bother with the gold valves, as they are made of brass and besides polluting your suspension fluid with small brass particles, they wear out pretty quickly. Dan Kyle at Kyle USA does a great job with the OEM valving and a full polish job on the tubes to get rid of the tremendous amount of stiction the forks have. He also does Ohlins valves, but unless you are racing or just have money to burn, I would go for the reworked Showa valves.
abtech is offline
post #4 of 15 Old 09-15-2004, 2:55 PM
I don't mean to be a , but this is a related quesion. Will the polishing that Dan does on the forks, take out small scratches that may be causing fork oil leaks?
Rios929 is offline
post #5 of 15 Old 09-15-2004, 3:06 PM
crazycuRRie's Avatar
Reputation Power: 17
Send a message via MSN to crazycuRRie
Abtech, so if i have the gold valves in my forks now how concerned should i be with polluted fluid, whats the time frame of the break down of the valves. I ask cause ive never heard that and my Suspension guy has never mentioned anything like that to me before...
WSMC 954
Sponsor: Mach 1,Chicken Hawk Racing, LP USA, Suzuki Motor Corp.
crazycuRRie is offline
post #6 of 15 Old 09-15-2004, 4:30 PM
The last set of gold valved forks I took apart had turned the fluid brown (not unusual by itself) until closer inspections revealed that it was METALLIC brown. The valves were installed at the beginning of an 8 race season (with Friday open practice days) and by the 7th weekend, the damping had gone off. When I looked at the vlaves, it was evident that they were slightly rounded and showed shiny wear spots both at the orifice faces and where they contacted other internal surfaces. After dissassembly I did some very non-scientific testing (a screwdriver scored across the valve face with light hand pressure) and wasn't surprised to see that the brass was relatively soft and left material on the screwdriver tip.
Several years ago when cartridge forks were a novelty, the Gold Valves offered a step up in performance. That time has long since passed and current OEM products are nearly an order of magnitude better in terms of materials and tolerances. The biggest thing about ANY revalving is changing the flow rate at high speed which can easily be accomplished with the OEM internals.
abtech is offline
post #7 of 15 Old 09-17-2004, 9:54 PM
what about the traxxion axion valves, any problems with these???
03' Blk/Tit CBR 954rr, Erion full system, PCIIIr, Scott's Damper, Vortex Frame Sliders, Galfer SS Lines, Rear Seat Cowl, flapper pinned.
vertical954rr is offline
post #8 of 15 Old 09-18-2004, 10:55 AM
HondaGalToo's Avatar
Reputation Power: 31
I think the general consensus on those is that they're worse than the Racetech stuff. Really, the best, most cost effective thing to do is to send them to Dan Kyle and let him put in the correct spring for your weight, revalve the stockers, and polish. After he massages them, they work about 90% was well as Ohlins forks, according to the guys here that have used both.
HondaGalToo is offline
post #9 of 15 Old 09-18-2004, 11:03 AM
There are people who swear by them, while there are just as many that swear at them. The orifice size and shape on the Axions doesn't seem optimum for most non-Suzuki applications and the casting/machining is very crude compared to the Showa or Ohlins available for the newer Hondas.
abtech is offline
post #10 of 15 Old 09-18-2004, 12:47 PM Thread Starter
I spoke with Dan and am going to be shipping them after the 25&26 track days I am scheduled for. I had asked Dan if I should have him put in the Ohlin valves during the revalving and he basicly said there was no advantage, so I will be getting ne Ohlins springs and Dans magic. Then the delima a new Ohlins rear or new Tires for the car... (as long as the snow stays away I know what I would rather do)
RayGun is offline
post #11 of 15 Old 09-18-2004, 8:08 PM
does dan kyle remove the honda hmas damping sysytem?
post #12 of 15 Old 09-18-2004, 8:12 PM
what does he charge to do a fork job with ohlin springs & valves?
post #13 of 15 Old 09-19-2004, 1:10 AM
does ohlins valves have the same problem as racetech??
post #14 of 15 Old 09-19-2004, 8:11 AM
No, they aren't made of brass.
abtech is offline
post #15 of 15 Old 09-19-2004, 8:12 AM
, Call him and ask . . .
abtech is offline
Fork Springs jnonny Honda FireBlade 3 06-24-2004 12:42 PM
Changes to damping after changing fork springs ? mickyboy Honda FireBlade 16 02-09-2004 5:41 AM
Fork Springs question gerry Honda FireBlade 11 02-05-2004 6:28 PM
Bike Handles Like Ass GoatRacer Honda FireBlade 22 10-17-2003 6:14 PM
New fork springs CBRjack Honda FireBlade 28 07-17-2003 7:00 PM
