rear tyre profile.. - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 10-28-2004, 11:32 AM Thread Starter
Reputation Power: 17
rear tyre profile..
I currently run a 180/55-17 like most people in this world and some of us run 190/50's however, has anyone tried a 190/60-17???
a 180/55 rear produces a height of 531mm
a 190/50 rear produces a height of 527mm
a 190/60 rear produces a height of 546mm
I understand why a 180/55 rear on a litre bike provides better turn in than say a 190/50 however, what would a 190/60 create? a better improvement or a complete nightmare?
has anyone used that size yet?? i'm tempted to try.
Look, Lean, Believe..
CBRSP2 is offline
post #2 of 23 Old 10-28-2004, 12:02 PM
Re: rear tyre profile..
I've never seen a 190/60. Who makes them?
CBRGuy is offline
post #3 of 23 Old 10-28-2004, 12:04 PM
dunlop. You'll likely need to lengthen your chain to use that tire. Its VERY BIG!
ccwilli3 is offline
post #4 of 23 Old 10-28-2004, 12:23 PM Thread Starter
you know not how loose my chain be
benefits to this size in tire????
don't keep us in the dark!
CBRSP2 is offline
post #5 of 23 Old 10-28-2004, 1:45 PM
I just moved up to the bigger dunlop 190/60 or 65/17 dot gpa race tire...it's the same 195/xx/17 slick. It's 13mm taller than the dot 180/55. So you may need to lower your shock a bit 6.5mm to maintain same rear height. I had to get a longer chain, rear axle was moved back about 1/4" or so, near the limit of adjustment (get a good chain that won't stretch too much) lengthening the wheelbase...so I only changed my shock height by 3mm or so. I also put some washers under the hugger bolts to raise it up a touch...may or may not be needed if the wheel is back far enough but I wanted to count for the tire expansiona at high speeds.
The beni's....More F-n Grip!!!!! If your spinning up the rear often, you will find the hastle of the change WELL worth it! Trust me! I still spinn it up but there is so much more grip. It's a heavier tire..but the bigger contact patch makes up for it. It feels planted. The dunlop guy tells me they haven't sold a 180 at a ama race in quite a while...I now understand why! You can really get on the gas harder and sooner!
Another beni is that once setup for that size tire you can switch from dot to slicks w/o chassis changes..same size.
02FBlade is offline
post #6 of 23 Old 10-28-2004, 2:51 PM
I am running the 190/63 17 slick from Bridgestone and like it a lot. It has the same diameter as their 180 slick, so the ride height didn't change but it does have a bit more meat at the edges.
abtech is offline
post #7 of 23 Old 10-28-2004, 7:26 PM Thread Starter
i'm sold... going in that direction "fo sheezy"
is that what the kids are saying these days
CBRSP2 is offline
post #8 of 23 Old 10-28-2004, 7:31 PM
There's no 190/55ZR17 in your list!!
I like my 180/55s.
-Rob.
SpikedLemon is offline
post #9 of 23 Old 10-28-2004, 8:38 PM
Were you using a stock length chain that needed to be lengthened?
01 CBR 929
08 Ducati 1098
Florida Trackdays
GiveGab
fl-929 is offline
post #10 of 23 Old 10-29-2004, 10:38 AM
Nah. Trashed the stocker for lighter 520 kit long ago. You dont want to lengthen any old/used chain...buy a new one. I suggest a 520 chain & spocket kit. Drop one tooth in the front and up 2 on the rear. The bigger rear will effect the gearing a touch. I had -1 on the front & stock sized rear (43) before changing to the big rear tire. Now have -1 on the front +2 on the rear...still could go lower for most tracks but I'm happy with it for now. You'll have to have the axle back to the last 1/4-1/2" of adjustment in the back for clearance.
For deals on chains & sprockets hit up my sponsor.... 10bombmotorsports = www.10.bomb.com Web is still being upgraded but he can get about any parts you need.
02FBlade is offline
post #11 of 23 Old 10-29-2004, 11:08 AM Thread Starter
so we get to the bottom of this... good sales tactict
but he can't help me being here in the UK
CBRSP2 is offline
post #12 of 23 Old 10-29-2004, 12:35 PM
Administrator
Red Rider's Avatar
Reputation Power: 47
Pirelli and Metzler both make a 190/55. I've been running that size for some time now and like it.
Red Rider is offline
post #13 of 23 Old 10-29-2004, 1:04 PM
Sorry, what I meant is if it was necessary to lengthen the chain (any chain) to run the 190/60 or can you leave the original length. You added two teeth on the back so I'm assuming you needed a longer chain, but did you have to further lengthen to accomodate the tire?
01 CBR 929
08 Ducati 1098
Florida Trackdays
GiveGab
fl-929 is offline
post #14 of 23 Old 10-29-2004, 2:16 PM
hmmmm could it be because it's the same tire with a different finish cut?
abtech is offline
post #15 of 23 Old 10-29-2004, 2:22 PM Thread Starter
you might be onto something here...
CBRSP2 is offline
Tyres - or is that Tires ? Spanky Honda FireBlade 18 10-20-2004 3:39 PM
Rear Brake Pad swap 41ants Honda FireBlade 3 10-19-2004 9:23 PM
BT020 rear tire with high perf front tire JWHT Honda FireBlade 4 09-05-2004 6:37 AM
Dunlop 208 GP Profile Change Chrome Dome General Discussion 7 07-27-2004 4:37 PM
Chopped the rear fender off finally. Pics! JWHT Honda FireBlade 7 07-07-2004 12:38 PM
