954 fuel pump won;t work - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 10-30-2004, 5:38 PM Thread Starter
I just changed the forks and left clipon on my 954. all the fairings are off. I basically turn the key, the cluster lights up but the bike doesn't do its ignition cycle, you don't hear the fuel pump prime. The bike is in neutral, the stand is up and the kill switch is on but still no fuel pump sound. If i hit the starter the bike turns over like usual but no fuel is being fed. You just hear the starter turning and that's it. Any ideas anyone?
mimic is offline
post #2 of 7 Old 10-30-2004, 6:59 PM
showmethebombs's Avatar
Reputation Power: 23
Re: 954 fuel pump won;t work
I would use a voltage tester to see if it is getting power. also check all your fuses.
Team Honda - well sorta...
showmethebombs is offline
post #3 of 7 Old 10-31-2004, 5:34 PM Thread Starter
I checked the fuses, they're all fine.
mimic is offline
post #4 of 7 Old 10-31-2004, 5:50 PM
soon2b954's Avatar
Did you lift the fuel tank up at all? If so, check for pinched hoses.
soon2b954 is offline
post #5 of 7 Old 10-31-2004, 6:23 PM
cbr99xx's Avatar
Quoted: 27 Post(s)
Reputation Power: 27
Did you disconnect the bank angle sensor? It is in the nose of the 954.
http://www.ronayers.com/fiche/200_03..._harness_2.cfm
#9 on this schematic from Ron Ayers site (#2 wiring harness diagram).
Life always looks better through bugs on a face shield.
cbr99xx is offline
post #6 of 7 Old 11-01-2004, 8:58 AM Thread Starter
HAHAH I'm a retard, I had installed the bank sensor on up side down. WOW, talk about stupid, thnx a bunch guys!
mimic is offline
post #7 of 7 Old 07-30-2005, 6:49 PM
I am putting a 954 together and I'm having the same problem. When I get home I will look for the bank angle sensor and make sure I have it first, then see if its upside down second. I have been finding things missing one after another because I got this bike in box's.......
All I know for know is my fuses are good and I have no power to the pump, but if I run a hot wire from the battery it primes but only with the key off. The project has been one problem after another.
Junk Yard Dog is offline
Third Annual FireBlades.org Member Roast ConqSoft General Discussion 55 06-10-2004 3:05 PM
929 and 954 fuel pump the same? Ripfuel Honda FireBlade 2 05-03-2004 10:30 AM
fuel pump ?'s Shorgasm General Discussion 7 03-10-2004 8:17 PM
954 fuel tank removal/installation synrrgy Honda FireBlade 13 01-15-2004 1:42 AM
What is this stuff in my fuel pump? Joelorama Honda FireBlade 6 07-07-2003 9:33 PM
