954 engine knock - Honda Motorcycles - FireBlades.org
post #1 of 13 Old 11-05-2004, 1:41 PM Thread Starter
954 engine knock
I have an '03 954 with about 18,000 km's. Always over maintained and pampered, but ridden moderately hard. 99% sport riding/touring, a couple of track days. Frequent oil changes. Last year detected some infrequent knocking from the engine, usually at idle, going away with increased rpm. This year, knocking is more frequent and only occasionally do I not hear it. Has anyone else on the forum experienced this? I've spoken with another 954 owner who has the same problem. Honda says "we haven't heard anything like this". Any help appreciated.
sullijs is offline
post #2 of 13 Old 11-05-2004, 2:48 PM
nedro's Avatar
Reputation Power: 27
Re: 954 engine knock
Sounds like your oil pump is giving out.
Ride Red
nedro is offline
post #3 of 13 Old 11-05-2004, 3:07 PM
CBR929RE's Avatar
Reputation Power: 39
take a long screwdriver or pry bar, put the handle against your ear and the other end on different parts of the engine and see if you can hear where the noise is coming from. once you locate the general place in the engine where the noise is you have it narrowed down to whatever is in that part of the engine. Learned this trick from a friend's father who is a mechanic, we all call him The Legend because as he says "if it has an engine I can fix it"
CBR929RE is offline
post #4 of 13 Old 11-05-2004, 3:08 PM
Or buy a stethoscope.
ConqSoft is offline
post #5 of 13 Old 11-05-2004, 3:17 PM
CBR929RE's Avatar
yeah but then you might slip and burn your hand. how high a temp can a stethoscope handle? the screwdriver/pry bar way doesn't involve buying anything since you probably already have one. the longer the better so you can get your head away from the total noise of the engine.
CBR929RE is offline
post #6 of 13 Old 11-05-2004, 3:40 PM
http://www.fcsurplus.ca/shopping/shopexd.asp?id=1485
2OHOH2 is offline
post #7 of 13 Old 11-05-2004, 3:43 PM
CBR929RE's Avatar
Originally Posted by 2OHOH2
you know what you still gotta go buy that.
that thing looks like it'd be a good investment for a mechanic though.
CBR929RE is offline
post #8 of 13 Old 11-05-2004, 4:11 PM
Reputation Power: 17
There have been cases of "knocking" due to piston scuffing. The pistons in the 954 (as in other brands/models) have little or no "skirt". Essentially you have the piston top and just the bosses that hold the wrist pin. The crown of the piston is approximately 5/8" or 16mm thick. In addition the "skirts" have a moly coating. The only fix is replace the top cylinder and pistons/rings.
If your bike is still under warranty, Honda "should" repair it. But to get Honda to warranty the problem, you have to have your dealer tear the motor apart to see if this is the problem.
Sugoi8
Sugoi8 is offline
post #9 of 13 Old 11-05-2004, 4:39 PM
nedro's Avatar
Sugoi8
Then why would the noise go away when the RPMs go up?
Conq: Good one! Just make sure that when using the mechanics Stethoscope, DO NOT SMACK IT AGAINST ANYTHING HARD!
Don't ask me how I know this.
Ride Red
nedro is offline
post #10 of 13 Old 11-05-2004, 6:59 PM
Intimidator's Avatar
I think I may know what you're talking about. I'll hear a knocking sort of noise coming from the engine for about the first 8 seconds after startup when it's been sitting overnight. Otherwise, it makes no noise. When it does it, it seems like more of an intermittent sound, unlike a typical old chevy engine cold startup knock. My buddy has an 03 954RR that does the exact same thing. The other day I changed the oil and it did it waaay worse for about the first 5 startups. No idea why though.
Intimidator is offline
post #11 of 13 Old 11-26-2004, 8:42 PM
i just bought a 2003 954 and the bike makes the same noise when it is cold and evrery couple of minuites after but no noises when i give it throttle i only have 1200 miles i'm going to get it checked out and i'll let you know
rogerjt is offline
post #12 of 13 Old 11-26-2004, 10:04 PM
CBR929RE's Avatar
try my long screwdriver tip, it worked for him.
CBR929RE is offline
post #13 of 13 Old 11-26-2004, 10:59 PM
Try decarbing with some seafoam or gm top end cleaner,seems to help a lot of engines that have piston slap/knocking in the a.m.
jafo is offline
954 Engine Swap Info Latebraking Honda FireBlade 12 11-26-2007 5:46 PM
will a 954 engine fit in a 929 frame bdavis24 Honda FireBlade 0 10-01-2004 10:36 AM
954 engine modifications n0xiu1 Honda FireBlade 17 06-18-2004 12:29 PM
954 Engine...What Will I Be Missing? Sprusgoose Honda FireBlade 5 05-22-2004 10:43 AM
has anyone bolted a 954 engine onto a 929 guru929 Honda FireBlade 2 05-20-2004 9:54 PM
