929 tank removal - Honda Motorcycles - FireBlades.org
post #1 of 12 Old 11-09-2004, 10:01 PM Thread Starter
929 tank removal
Is there a way to take the tank off without spilling any gas? As soon as I crack the banjo bolt on the pressurized line, it starts to spill. Is there a shutoff valve some where?
jcblitz is offline
post #2 of 12 Old 11-09-2004, 10:04 PM
Re: 929 tank removal
Nope... Need to drain the tank first. If you're going to be doing it a lot, you may want to install some quick-disconnect thingies.
ConqSoft is offline
post #3 of 12 Old 11-09-2004, 10:10 PM
ditto; use a margarine container or something to catch the last bit - it helps to have another hand to hold everything.
-Rob.
SpikedLemon is offline
post #4 of 12 Old 11-09-2004, 10:14 PM
You could also use any sort of small clamping device (needlenose vise grips with tubing covering the ends, carpentry clamps, etc), or plug the hose ends with something like bolts/pen caps/etc after you pinch them and disconnect them.
2OHOH2 is offline
post #5 of 12 Old 11-09-2004, 10:16 PM Thread Starter
It figures, I have a full tank of gas. Thanks.
jcblitz is offline
post #6 of 12 Old 11-10-2004, 12:55 AM
Do you HAVE to remove the tank for some reason? Most normal maintenance can be done by tiping the tank up on it's "tail" and tying it off. There used to be a pic in the KB section of this technique.
Joel is offline
post #7 of 12 Old 11-10-2004, 8:57 AM Thread Starter
I have to replace the throttle cables.
jcblitz is offline
post #8 of 12 Old 11-10-2004, 8:59 AM
You should be able to just unbolt it and prop it up. Some of the 929's had a short (too short, 'cause it was recalled) fuel line to the tank though, so be careful you don't pull too hard...
ConqSoft is offline
post #9 of 12 Old 11-10-2004, 11:06 AM
Joel is offline
post #10 of 12 Old 11-10-2004, 11:50 AM Thread Starter
I don't know if the recal has been done on my bike. They punch the frame if they do right?
(don't mind the 900 directory, its the 929)
jcblitz is offline
post #11 of 12 Old 11-10-2004, 11:54 AM
Not all 929's had the short hose. Just lift the tank carefully and you should be able to tell if the hose begins to bind.
ConqSoft is offline
post #12 of 12 Old 11-12-2004, 2:08 PM
Consoft trying to get those quick-disconnect thingies?? Where should i start looking??
CBR929Junkster is offline
954 gas tank on a 929? YCBR929RR Honda FireBlade 2 11-08-2004 11:11 AM
954 tank on 929? ulysses_sc Honda FireBlade 1 10-21-2004 1:08 PM
2000 929 Tank??? Chrome Dome Honda FireBlade 4 09-20-2004 7:23 PM
Replacing 929 tank?? CBR929Junkster Honda FireBlade 2 07-16-2004 8:00 AM
tank removal??? ughhhhh batman Honda FireBlade 6 02-20-2004 8:18 PM
