954 stock exhaust.. - Honda Motorcycles - FireBlades.org
post #1 of 23 Old 11-23-2004, 8:40 PM Thread Starter
FHL
954 stock exhaust..
I need an EGCV for my exhaust for it to work. What's the best way to go about getting one of these. I don't know naything about it so should I have my mechanic install the whole exhaust system for me?
FHL is offline
post #2 of 23 Old 11-23-2004, 8:51 PM
SomeStrangeGuy's Avatar
Reputation Power: 34
Re: 954 stock exhaust..
what the hell are you talking about?
You mean HTEV? the valve on the exhaust collector?
..or your FI light is just blinking?
SomeStrangeGuy is offline
post #3 of 23 Old 11-23-2004, 9:18 PM Thread Starter
FHL
It said EGCV in my service manual. Yeah what I need is an HTEV. How should I get one and should I get it installed?
FHL is offline
post #4 of 23 Old 11-23-2004, 10:40 PM
It is a piece that exists on the stock honda exhaust system after the header and before the exhaust.
Your bike will run with it, just not optimally. Most folks with full systems have to lose the HTEV when they put on their full system, an HTEV cannot be added to an aftermarket system (reasonably). Might lose a bit on the bottom end and some fuel efficiency if you do not have an HTEV.
If you have a full stock system and do not have an HTEV on it you will need one to connect the pieces of the exhaust with one another. It goes under the bike somewhere afore the oil pan right after the collector. has some cables and junk going to it.
post #5 of 23 Old 11-23-2004, 11:08 PM
CBR929RE's Avatar
Reputation Power: 39
or just get an HTEV eliminator and not have to worry about hooking up cables. I think a little info is still missing, FHL do you have the rest of the stock exhaust, is your HTEV broken, do you have a full exhuast, its gotta be one of those 3 I assume.
CBR929RE is offline
post #6 of 23 Old 11-23-2004, 11:37 PM
you mean the sensor piece to eliminate the FI light? You could just disconnect the cables and make sure you don't touch the sensor (I did) if that was the case too.
I just have no idea where the problem exists here, and it's already 5 posts old...
post #7 of 23 Old 11-24-2004, 12:56 AM Thread Starter
FHL
The whole exhaust is there, the HTEV valve is there too, it just has 4 bolts and nothing on it. I really want it on the bike cause I can tell now that I took my PCIII off my Arata it's going to run like **** in the bottom end without it. I didn't really much like the power band of the Arata exhaust anyway I'd rather have the low end of the stock exhaust.
I'm just asking should I get oem parts from my mechanic and have him install it since I have no clue where to put the wires, or try to buy one off ebay first.
FHL is offline
post #8 of 23 Old 11-24-2004, 1:32 AM
Intimidator's Avatar
I'm still confused This is the wierdest post I've seen on the .org yet. Now I appreciate Chain's verbose, yet unambiguous posts.
Intimidator is offline
post #9 of 23 Old 11-24-2004, 1:34 AM
ok...so it sounds like the whole stock exhaust is there? and the HTEV is maybe missing a pulley?
Id say skip the OEM thing and look for something off ebay...that part is like 300$ from a dealer I think, maybe more.
But...the arata is entirely off, or you have an arata slip on on the OEM pipe?
am I remotely with the program here?
am I helping?
am I evil?
post #10 of 23 Old 11-24-2004, 1:47 AM Thread Starter
FHL
am I helping?
am I evil?
Yes I am...
It's the full exhaust let me take a picture and get back to you in a couple of minutes.
FHL is offline
post #11 of 23 Old 11-24-2004, 1:53 AM Thread Starter
FHL
My brother took it I guess. Anyway, the midpiece between the header and midpipe is there but there's just a hole with the motor would normally be.
FHL is offline
post #12 of 23 Old 11-24-2004, 1:56 AM Thread Starter
FHL
http://i22.ebayimg.com/02/i/02/da/5f/5c_1_b.JPG
Where that would be it's open.
FHL is offline
post #13 of 23 Old 11-24-2004, 2:05 AM Thread Starter
FHL
Does anyone have one that I could buy off them if they replaced their stock system with a full exhaust?
FHL is offline
post #14 of 23 Old 11-24-2004, 6:40 PM
post #15 of 23 Old 11-24-2004, 8:39 PM Thread Starter
FHL
WTF someone help me!
FHL is offline
954 to 929 exhaust swap question Uncle Jesse Honda FireBlade 11 05-19-2010 7:53 PM
Can U modify Stock 954 exhaust can for better sound? hwy74 Honda FireBlade 44 01-27-2008 4:46 PM
Which exhaust and map for my '03 954? Hellfire666 Honda FireBlade 19 03-07-2005 12:13 AM
954 Stock Exhaust Question vader56 Honda FireBlade 10 04-15-2004 3:47 PM
PCIII Maps for stock CBR 954 Joelorama Honda FireBlade 1 06-26-2003 9:34 PM
