Gear shift question - Honda Motorcycles - FireBlades.org
post #1 of 4 Old 12-04-2004, 5:00 PM Thread Starter
Gear shift question
My bike usually shifts pretty smoothly, but sometimes, shifting up into 4th and 5th, the shift lever seems to go about 3/4 of the way, stops, and then goes the rest of the way up. I can feel it down shifting from the same gears too. Is this a problem, or what? It seems less likely to happen if I shift at a higher RPM. Of course I don't feel it if I shift without the clutch. Thanks!!
1pcbr is offline
post #2 of 4 Old 12-04-2004, 5:46 PM
CBRBob's Avatar
Re: Gear shift question
Maybe you have corrosion in the shift lever pivot. Try disassembling it, clean it out and re-lube it. While the linkage is off, try shifting with just the rod, this will eliminate the shift lever from the problem.
CBR Bob
TeamPromotion Coach#29TPM
CBRBob is offline
post #3 of 4 Old 12-04-2004, 8:52 PM Thread Starter
OK, thanks.
1pcbr is offline
post #4 of 4 Old 12-04-2004, 10:42 PM
Another thought is to preload the shift lever prior to and during the shift. That is, lift up on the shift lever prior to pulling the clutch lever in. This should make your shifts smoother and make your transmission last longer.
Joel is offline
Gear noise on the 1000RR Max Honda FireBlade 5 03-18-2014 6:37 PM
Shift light/Gear indicator? 02FBlade Honda FireBlade 2 11-17-2004 12:41 PM
954 Transmission question 954WRECKER Honda FireBlade 2 08-26-2004 10:05 PM
00 929 won't shift into 3rd sometimes 107 Honda FireBlade 4 08-03-2004 12:49 PM
First Gear vs. Vanson? Joel Riding Gear / Luggage 15 07-24-2003 12:39 PM
